Changed BCM need help!!!
Old Oct 5, 2010 | 03:16 PM
jetstreamC5's Avatar
jetstreamC5
Default Changed BCM need help!!!
Ok I have a 99 A4 coupe and my BCM went out so I got another off a forum member that came out of a 00 A4 coupe with the same options as my car everything works but I can't get the car to crank over and I checked the battery and its good.
So does anyone know if theres somthing I have to do or what the problem might be?
Old Oct 5, 2010 | 04:15 PM
lucky131969's Avatar
lucky131969
Originally Posted by 8VETTE7
Did you do the BCM-PCM relearn procedure????? If not it ain't going to run.. From a post I copied a ways back:
BCM/PCM RELEARN PROCEDURE
You will need to conduct the PCM/BCM relearn process. This matches their handshake ID's and allows them to talk to each other.
Do this before you worry about VATS issues:
1. Turn on the key for 11 minutes.
2 Turn off the key for 30 seconds.
3. Repeat 1&2 two more times.
4. Turn on the key for 30 seconds.
The car should start and run with the new B
CM
Old Oct 5, 2010 | 07:40 PM
jetstreamC5
CM
thanks man you always help me out your a life saver.
Old Oct 6, 2010 | 11:06 AM
BigGun's Avatar
BigGun
Make sure you have a full charge on your battery before you start this procedure or you may run out of juice before it completes the cycles.
Old Oct 6, 2010 | 03:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Let us know if it work and runs. if not,, pull and post the DTCs
BC
Old Oct 6, 2010 | 04:38 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Just the FYI for the OP, the BCM and PCM exchange a hidden password between them therefore preventing someone from stealing your car by changing out the BCM and using the wrong key. If the password exchanged between them doesn't match on both ends, the starter will not function. The relearn will take care of this although it will not match up RPO codes. If you vehicle is identical to the one the BCM came out of, all should work but if not, you'll need either a Tech 2 or a trip to the dealer.
Old Oct 6, 2010 | 04:50 PM
lucky131969
Actually...no. If the BCM is not satisfied with the key value, then the starter will not function...as a result of the TDR not being enabled. If the BCM does not pass on the correct password to the PCM(or no password at all), the PCM disable the fuel injectors.
Old Oct 6, 2010 | 09:06 PM
dgrant3830's Avatar
dgrant3830
hmmm....I thought I read that area of the manual carefully on the '99 that I gave away to my son. Since I'm getting it back shortly and the manuals, I'll re-check what I thought I read. For now, I'll assume I'm wrong and you are correct. Either way, if things aren't satisfied, it won't start!
Old Oct 6, 2010 | 09:08 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
To Changed BCM need help!!!
