fuel door removal help
Old Oct 6, 2010 | 09:21 PM
Bullet Proof's Avatar
Bullet Proof
Default fuel door removal help
need to take the fuel door into the paint shop to get a paint match. I removed the cap retaining strap and removed the 7mm bolt that is visible when the door is open...what am I missing to remove...and where is it?
Old Oct 6, 2010 | 09:40 PM
Bullet Proof
figured it out
thanks
Old Mar 3, 2011 | 10:56 AM
bigblueman's Avatar
bigblueman
After you remove the bolt. Could you please tell me how to remove the fuel door.
Thanks Doug
Old Mar 4, 2011 | 08:29 AM
bigblueman's Avatar
bigblueman
any help
Old Aug 13, 2011 | 11:45 PM
IDM's Avatar
IDM
I have the same question, anyone know how to remove the fuel door?
Old Aug 14, 2011 | 11:29 AM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Once you remove the screws you have to pull hard and wiggle the assembly to get it past the filler pipe...it is tricky...I've done it a few times and it is never the same each time. Reinstalling is easiest if you put the far screw on the end of a magnetic screwdriver.
Old Aug 14, 2011 | 11:31 AM
$$$frumnuttin'
Glad you got it finally..just a tip for anyone wanting to take a part for paint match. It would be way easier to take your front filler plate if you live in a no plate state, or one of your headlight covers.
Old Aug 14, 2011 | 01:11 PM
IDM's Avatar
IDM
any better instructions?
There is one bolt on the fuel door that comes off. Then remove the star screws? what else?
thanks
Old Aug 14, 2011 | 01:48 PM
IDM's Avatar
IDM
Hi got it off, wanted to make sure I didn't get stuck.
Basically take off the screw deep inside as you look to the left with the fuel door open.
Then take off all the other screws surrounding the opening to make it easier. Now twist and get the fuel door to break loose and wiggle it out of place.
I am guessing everyone doing the fuel door mod puts back their gas cap for pressurization.
I used the first screw mentioned to hold the gas cap anchor down. Not sure if that will work with the breathless setup once pumping gas, will let you know soon.
Thanks guys.
Old Aug 14, 2011 | 05:27 PM
$$$frumnuttin'
Thanks guys.
yes, put the cap back on so you don't drop a screw into the tank!
To fuel door removal help
