oil filter c5
Old Oct 10, 2010 | 08:46 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Just an "FYI" regarding the Mobil 1 filters....they're about 1/2" longer than an AC Delco filter, so if you're driving a car that's "slammed", you may want to pass on the Mobil 1, as it hangs lower than the oil pan.
Old Oct 10, 2010 | 09:10 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
Wix makes the best filters.
They are made under different brand names too. From what I remember they are the largest filter manufactor.
If you go to Wally World you will mainly see Fram and those are not made by Wix.
Old Oct 10, 2010 | 08:54 PM
bassfisher's Avatar
bassfisher
So what's wrong with the PF-44? I've been using the Black UPF-44 for 11 years.
Old Oct 11, 2010 | 01:31 AM
LT1driver's Avatar
LT1driver
the 44 is production filter, 46 what you get at the counter now unless dealer still has the 44s, either are fine.
Old Oct 11, 2010 | 02:17 AM
Old Horsepower's Avatar
Old Horsepower
Are the 44 and the 46 the same length? Do they look the same? Ive been using 44's and didnt even know there was a 46.
Old Oct 11, 2010 | 07:10 AM
leadfoot4's Avatar
leadfoot4
The black UPF-44 has a special synthetic filtering element. It's a 'top shelf' filter....
Old Jul 22, 2014 | 02:05 PM
kenpla2's Avatar
kenpla2
Cruising
Default Wix Filters FYI
Originally Posted by Bullet Proof
mobile1 and wix are really good filters...I use whichever is on sale.
Just so you all know....WIX makes all filters for NAPA, so if you know a WIX # for an air,fuel,or oil filter, all you have to do is DROP the first # & that is the exact NAPA #. For example a #51515 Ford oil filter is a #1515 @ NAPA. Also WIX's first # designates the type of filter....5 is always oil, 4 is always air, & a 3 is always a fuel filter. Been this way for over 40 years. Check it out when pricing out & crossing over filters. Sometimes it saves you money, when you are paying for ( the name ), not knowing they are exactly the same !!!!
Old Feb 17, 2015 | 12:06 PM
cmark84's Avatar
cmark84
I change my oil in the first of spring, summer, and end of fall. That way the oil never has more than 3 months of use on it. I never hit the mileage required of synthetic anyway.
Old Feb 17, 2015 | 03:03 PM
leadfoot4's Avatar
leadfoot4
How many miles do you drive, in that time frame? Sounds like you could be wasting a LOT of money, as well as oil...
