Need help draining coolant
Old Oct 10, 2010 | 10:09 PM
Hunster's Avatar
Hunster
Cruising
Default Need help draining coolant
03 Z06 pulled the radiator plug today and only got 3 quarts of coolant out. What's going on? Everything I read says it's easy to get 2 gallons out. Any ideas out there what I'm doing wrong? Does the engine have to be hot for the thermostat to be open or something I'm missing? Only have 15K miles on it. Coolant is very clean.
Old Oct 11, 2010 | 01:53 AM
Edmond's Avatar
Edmond
I just unbolted the thermostat (only 2 bolts), lots of coolant came out that way.
Old Oct 11, 2010 | 07:35 AM
Hunster's Avatar
Hunster
Cruising
Thanks for the info. My thinking now is that the drain process involves siphoning and I may have interupted the process by starting and stopping the flow, thereby only draining the radiator. I'll try again next weekend, thanks. How much more did you get by pulling the bottom hose?
Old Oct 11, 2010 | 10:04 AM
Fast one's Avatar
Fast one
I took off the thermostat/ housing which is held on with two bolts then used a garden hose to flush out all the passages, this will clear out the block and heater core. When the water ran out clear from all passages the thermostat/ housing was replaced then the system was filled with tap water and antifreeze. My experience with deionized water is that it corrodes metal since it is hungry for ions.
Old Oct 11, 2010 | 10:45 AM
LoneStarFRC's Avatar
LoneStarFRC
That's a good process for flushing etc.
Personally I like prefer to use distilled water.
Old Oct 11, 2010 | 04:49 PM
bighank's Avatar
bighank
Default I drain and pull the overflow tank and add water with a hose
First drain the radiaror. Remove expension tank and use one of the hose connections to flush with water from garden hose while running engine. Let drain and repeat. Let thermostat open to ensure flushing whole system. After about 3 cycles and when coolant runs clear let it drain one last time. Then add full strength Dexcool till the radiator is full. Run engine and heater on full heat to get the air out of the system. Add more full strength Dexcool to tank and check level for the next 2 weeks.
Old Oct 11, 2010 | 04:52 PM
lucky131969's Avatar
lucky131969
So you are suggesting adding Dexcool as is.....and not a 50/50 mix with water?
Old Oct 11, 2010 | 04:56 PM
LoneStarFRC
Pretty thorough process for flushing, except for one thing. No need to run the heater on "full heat". Unlike days of old, C5s do not have a heater control valve that cuts/ restricts water flow through the heater core. You can leave the heater and it's controls alone. Coolant still circulates through the core just fine.
Old Oct 11, 2010 | 04:57 PM
lucky131969
Originally Posted by 8VETTE7
A quote from page 6-402 of the 2004 GM Service Manual under Filling Procedure for the radiator:
"IMPORTANT: Use a 50/50 mixture of DEX-COOL anti-freeze amd deionized water."
....and if you look in the 97-01 service manual, is states "clean drinkable water"......and changes to "deionized water" in the 02-04 service manual.
To Need help draining coolant
