Winding Alternator
Old Oct 11, 2010 | 10:15 AM
wheelhorse's Avatar
wheelhorse
Default Alternator Whine
The alernator on my 98 is singing to me. Battery is fully charged and is on a "Battery Tender" when not in use. The digital gauge says it's putting out 14 amps with no loads applyed. We went for a ride Sunday and we noticed that the alternator was making a loader than normal whining sound. It was a warm day, we had the air on and at a stop the digital gauge was at 13.2 amps. If I put the directional light on or applyed the brake pedal on and off the whining sound followed the beat. The amps would very from say13.2 amps to 13.8. Is the alternator on it's way out?
Old Oct 11, 2010 | 10:17 AM
lucky131969's Avatar
lucky131969
Originally Posted by wheelhorse
The alernator on my 98 is singing to me. Battery is fully charged and is on a "Battery Tender" when not in use. The digital gauge says it's putting out 14 amps with no loads applyed. We went for a ride Sunday and we noticed that the alternator was making a loader than normal winding sound. It was a warm day, we had the air on and at a stop the digital gauge was at 13.2 amps. If I put the directional light on or applyed the brake pedal on and off the winding sound followed the beat. The amps stayed at 13.2 amps. Is the alternator on it's way out?
You mean volts, not "amps".....right?
Old Oct 11, 2010 | 10:50 AM
lionelhutz's Avatar
lionelhutz
Probably dry bearings. Take it apart and grease it.
Peter
Old Oct 11, 2010 | 12:25 PM
wheelhorse's Avatar
wheelhorse
Yes, Volts not amps. Bearings are sealed.
Old Oct 11, 2010 | 08:20 PM
wheelhorse's Avatar
wheelhorse
Must be normal?
Old Oct 11, 2010 | 08:38 PM
DIXZ's Avatar
DIXZ
Any chance you can explain a "winding sound"?
Old Oct 11, 2010 | 08:54 PM
sami85L98's Avatar
sami85L98
Since you cant drive than take the battery out first and check with autozone or some garage, once its sure that battery is good than take the DMM meter and check voltages before and after loads, both at battery terminals and than connect DMM neg to negative of battery and pos of DMM to terminal (it has rubber boot on) of alternator itself to make sure you getting same voltages.
For loads: turn A/C ON, interior lights ON, and headlights ON, W and W/O loads, alternator should compensate and shows same voltage....for example without loads you read 14.20V and you should read same voltage with LOADS ON or atleast very close to it.
If you alligator clips than put the DMM on window while you read voltage at idle and rev to about 2k rpm.
I suspect your battery is not in top shape or not chraging over 13V's, make sure first battery is good though. However if you getting winding sound than alternator might be suspect too.
Old Oct 11, 2010 | 09:29 PM
PEERPSI's Avatar
PEERPSI
This is what my recently departed alternator in my Ford Escape started doing. Analysis of it when it finally failed showed that one diode had a bad solder joint and two hours had overheated and failed. I suspect the whining noise was due to the fact a few of the only half the windings were carrying the load. In short the whining sound was due to overloaded windings. Bad bearings could also be the problem. Bear in mind the alternator has they smallest pulley out of all your accessories therefore it is turning the fastest.
Old Oct 11, 2010 | 10:12 PM
lionelhutz's Avatar
lionelhutz
Must be normal?
Not normal.
Easiest check is to remove the belt and spin it. No tools required.
Peter
Old Oct 12, 2010 | 09:24 AM
wheelhorse's Avatar
wheelhorse
You may be right. It has a yellow top battery. As I mentioned, I keep the Battery Tender on it when not in use. This morning I fired it up and was getting 14V. No whining noise. I then went for a hour ride with AC, fog lights and interior lights on. Voltage varryed from 13.2 to 13.8. but I was not getting a noticable winding noise. I'll check that battery.
I was also thinking DIODE or maybe the STATOR.
Old Oct 12, 2010 | 09:40 AM
Nver2loud's Avatar
Nver2loud
As stated above, please describe what a winding noise sounds like...
Old Oct 12, 2010 | 09:48 AM
wheelhorse's Avatar
wheelhorse
Like a low pitch siren. Increases when you rev engine or decreases when a electrical load is applyed.
Old Oct 12, 2010 | 12:58 PM
hotwheels57's Avatar
hotwheels57
Alternators have "windings" inside. It's called a stator.
Sometimes alternators "whine".
http://www.crutchfield.com/S-j0NOcZL...ech/kb348.html
Old Oct 12, 2010 | 09:37 PM
wheelhorse's Avatar
wheelhorse
Whining noise.
Old Oct 12, 2010 | 09:47 PM
wheelhorse's Avatar
wheelhorse
Whining sound.
Old Oct 14, 2010 | 12:01 PM
hotwheels57
Looks like the problem was solved...
http://forums.corvetteforum.com/c5-t...tor-whine.html
Old Oct 15, 2010 | 11:57 AM
wheelhorse's Avatar
wheelhorse
Sorry about that.
To Winding Alternator
Old Oct 15, 2010 | 12:16 PM
hotwheels57
To find your old threads (for updates), just click on your user name and select from the pull downs.
Did the source of the new VALEO require the core?
To bad there's so few places that rebuild or provide replacement parts for the newer alternators nowadays.
When customers bought brand new instead of rebuilding their parts, we used to call it "planned obsolescence" and that was was in the '60s.
Old Oct 15, 2010 | 12:57 PM
wheelhorse's Avatar
wheelhorse
I use to take them apart and check the stator, diodes, rectifier bridge, brushes and rotor. Then put a new regulator and bearings in. Good to go. It's hard to get individual parts for this alternator. No core required. I had no choice.
Old Oct 15, 2010 | 01:23 PM
hotwheels57
Save your parts. Someone might be interested in buying the cases to have them polished or chromed.
For older alternators for US made cars, I've found these two hot rod sources for parts to be outstanding...
http://www.enoscustom.com/
http://madelectrical.com/index.shtml
Mark Harmon runs the second site. He's an electrical guru. Unfortunately, his health hasn't been the best.
