Need a ecbm monitor
Need a ecbm monitor
Is there somone1 that does refurbs or where can i locate a new 1? My traction control and abs codes are off. i took it to dealership and they wanted 1300 to fix it. Help
Alright so i ran all of the codes accord to instruction. I ended up calling the dealer back and he told me he spoke with his boss and GMotors and can to the module for 650 with labor instead of 1324.00.Battery was replaced. Just wanna know if i should just spend the money to get this done or am i being ripped off? Anyway here is a list of the codes, im pretty sure the H codes do not matter but ive posted everything to be sure. Meanwhile I am still getting the following Info from Info Center..
Service ABS
Service Traction Control
Service Active hanlding
10PCM NoCodes
28TCS c1255 H C
C1248 H C
40BCM NO CODES
58SDM B1000 H
60IPC NO CODES
80 RADIO NO COMMUNICATION
99HVAC NO CODES
A0LDCM B2282 H
B2284 H
B2286 H
U1016 H
U1096 H
A1RDCM B2283 H
B2285 H
B2287 H
A6SCM B0851 H
B0856 H
BOREA U1000 H
Service ABS
10PCM NoCodes
28TCS c1255 H C
C1248 H C
40BCM NO CODES
58SDM B1000 H
60IPC NO CODES
99HVAC NO CODES
A0LDCM B2282 H
B2284 H
B2286 H
U1016 H
U1096 H
A1RDCM B2283 H
B2285 H
B2287 H
A6SCM B0851 H
B0856 H
BOREA U1000 H
Check out www.absfixer.com. I would clear all the codes and see if the TCS code (the only "C" code you have) returns.
28 TCS C1255:
EBTCM internal malfunction.
When DTC sets, code stored, ABS/TCS is disabled and ABS/TC indicators are turned ON.
Clearing:
DTC condition no longer present & Scan Tool is used.
Or 50 IGN cycles with not DTCs'.
Check CON between EBTCM and BPMV (tight and corrosion free).
Check for damaged, pushed out, or miswired terminals. Replace EBTCM.
28 TCS C1255:
Clearing:
Received 2,184 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
TOOOOOOOOO Many DTCs to see the real issue. Clear DTCs ,, make sure the batery is fully charged and see what comes back.
Repost most current DTCs
BC
BC
