PF44?
Old Apr 1, 2002 | 11:01 PM
Randy K's Avatar
Randy K
Default PF44?
I'm getting my stuff together to make the first oil change on my car and......
Is it me or does the PF 44 ACDelco filter seem alittle small? We are trying to filter 6.5 quarts of oil, and and extended drain period on top of that. They say the oil can last up to 10,000 miles between drains. I don't disagree, but I don't think the filter can handle 2000 miles. The filter looks like a lawn mower filter. Do I have the wrong one? I hope so...........
:confused: :confused: :confused:
Old Apr 1, 2002 | 11:02 PM
C5Noir's Avatar
C5Noir
Default Re: PF44? (Randy K)
You've got the right one. And yes it's tiny :D You'll be fine.
Old Apr 2, 2002 | 12:08 AM
BarryR's Avatar
BarryR
You might consider using UPF-44 filter. I think its the same size but has better filtering ability (8-10 microns vs 25-40).
Old Apr 2, 2002 | 12:21 AM
C5stein's Avatar
0C5stein
Former Vendor
Default Re: PF44? (BarryR)
Barry is right, the UPF 44 offers better filtration. We recommend that you change your oil filter when the DIC says that you are at 50% oil life. The oil still has plenty of "good" left in it but this technique keeps the oil cleaner. Plus a UPF is less than $15. you'll need to add a 1/2 quart of oil too.
Old Apr 2, 2002 | 01:13 AM
VERTVETTE's Avatar
VERTVETTE
Default Re: PF44? (C5stein)
:yesnod: :cheers:
Old Apr 2, 2002 | 10:25 AM
sunkenmel's Avatar
sunkenmel
Just remember that the UPF44 filter has been discontinued.
Old Apr 2, 2002 | 12:18 PM
Randy K's Avatar
Randy K
Default Re: PF44? (sunkenmel)
I did notice it was hard to find. Is there anything replacing it?
Old Apr 2, 2002 | 01:01 PM
GasmanZR1's Avatar
GasmanZR1
I was under the impression that they (AC Delco) had brought it back because of our compaining????
Old Apr 2, 2002 | 01:11 PM
Patman36's Avatar
Patman36
Default Re: PF44? (gasman29)
This is correct. Shawn at LAPD sells them by the case. Bob @ Fichtner Chevrolet sells them individually (might as well buy a couple...) but are currently out. They are pretty hard to find right now... I guess a good substitute if you don't want to use the PF44 is the Mobile 1 filter?
Patrick :D
[Modified by Patman36, 10:03 PM 4/2/2002]
Old Apr 2, 2002 | 01:36 PM
MDT's Avatar
MDT
sunkenmel,
True that the Gold line of filters has been discontinued, but the specific PF44 filter is still in production.
Good luck.
Mark
Old Apr 2, 2002 | 02:12 PM
ncvetteman's Avatar
ncvetteman
I use the Mobile 1 Filter, M1-107 I think... its a high-end filter usually $8-12. Everyone has an opinion, but I think its just as good or better than the "Gold" Delco one.
Some Fbody owner use a larger volume filter, the one for trucks, if your concerned about the volume.
[Modified by ncvetteman, 1:13 PM 4/2/2002]
Old Apr 2, 2002 | 04:35 PM
sunkenmel's Avatar
sunkenmel
Default Re: PF44? (MDT)
Mark,
When I heard they were being discontinued I bought a case.
Old Apr 2, 2002 | 11:49 PM
Patman36's Avatar
Patman36
Per this weeks "Bob's Parts" post (Ken Ficthtner's parts guru)...
We are out of the UPF44 filters at this time. AC DELCO is supposed to be shipping about mid April. I will post as soon as they are available again.
Patrick :cheers:
Old Apr 2, 2002 | 11:57 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
Default Re: PF44? (Patman36)
Guys,
We have a ton of the UPF44 filters in stock!
Yes, we do only sell them by the case, but if you buy a case which consists of 6 filters, you won't have to worry about buying some for awhile.
Price per filter is: $7.95 and shipping is only $5.00 per case, so you actually save money getting a case of them from us.
Shawn
Old Apr 3, 2002 | 12:09 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
I finally went to the PF-44 when I couldn't find anymore UPF-44's. Now I see that LAPD has some some maybe there's some hope after my current ones. I usually change around 30% on the DIC---which is around 5K miles.
To PF44?
