cam help
Old Oct 16, 2010 | 03:55 PM
SSoniC's Avatar
SSoniC
Default cam help
my buddy gave me a 236/240 601/608 114ls cam .will this cam work. my car is a 2002 z06 with dynatech long tubes ,corsa indy exhaust ,spec twin ,vr/power duct and a tune. i wont to put a new cam ,lifters,pushrods,valve springs before i spray a 100 shot thru it .i like to do low rolls not a strip car.. if any know of a better cam for what i am trying to do please let me know thanks
Old Oct 16, 2010 | 05:48 PM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
whats a low roll ? thats a semi big cam, the power will be more latent.. its not a street cam its more of a strip cam but that's all subjective.. some people think the trex is a street cam as well.
Old Oct 16, 2010 | 06:10 PM
manley845's Avatar
manley845
I'm researching for the same answer, I think. I want to install a Comp Cams cam and not sure how big to go.
From what I have found, going bigger than about 224ish @ .050" will not yield much more horsepower and may only negatively affect lower rpm torque.
But if you plan on installing better flowing heads then the 230 series cam would be great.
Personally, I'm stubborn and will probably run an LSr series Comp Cam with 231/230 @ .050" and .617/.624 lift. Honestly though, a 222 - 224 @ .050" should be max for stock heads based on my reading.
Just my thoughts, and I hope I'm wrong 'cause I wanna big cam too ha!
Old Oct 16, 2010 | 06:18 PM
SSoniC's Avatar
SSoniC
race starts at lets say 15mph to 20mph.
Old Oct 16, 2010 | 06:32 PM
Show Stopper's Avatar
Show Stopper
There are a lot of variables with cams. A LOT of people over cam their car. I don't remember how well stock heads flow, but that is what determines what cam to run. For example: Your heads could stop flowing at .600 lift, which means you wouldn't need anything above that. Also, you should REALLY change springs when you change cams to be on the safe side.
Old Oct 16, 2010 | 06:33 PM
99blancoss's Avatar
099blancoss
Former Vendor
You would be lucky if in 1st gear to even be in the power curve of that cam unless your going with 410 gears or something? I would be going no bigger than a 224 and even then your on the edge on the power-band. The 224 really doesnt kick until about 3200 rpms even though its adversed from 1800 or 2200 up .... you dont see appreciable power at that RPM.. it just starts to come alive then but doesn't kick hard until a little bit higher in rpms. 224/228 on a 111 might be ok or even as suggested a 222 duration.. but some people have a hard time swallowing a smaller cam and will always say something huge and impractical. Best way to do this is to have a custom cam ground. I send you a questionnaire to fill out and we spec it based on your answers.. takes all the guessing out of it. $425 to you door.
Old Oct 16, 2010 | 06:34 PM
99blancoss's Avatar
099blancoss
Former Vendor
big cam with ported heads with big runners is not a good combo unless your leaving the line at 5000 rpms or something?
Old Oct 16, 2010 | 06:44 PM
SSoniC's Avatar
SSoniC
sounds great my email is hawkr0ds@aol.com ..i doint wont to change my gear i just wont to update the valvetrain before i add nitrous thanks
Old Oct 16, 2010 | 06:50 PM
99blancoss's Avatar
099blancoss
Former Vendor
Sent, be on the lookout for it. I have an msn email address and it gets filtered sometimes by spam guards
Old Oct 16, 2010 | 07:01 PM
SSoniC's Avatar
SSoniC
got it. have it back shortly thanks
To cam help
