Multiple misfire
Old Oct 17, 2010 | 08:29 PM
alanmtz's Avatar
alanmtz
Default Multiple misfire
I have a rough idle at around 1100 rpm. When i accelerate past 1100, the car seems just fine. The ses light was flashing yesterday so i took the car to the auto parts to pull the code. And not to my astonishment i had a misfire code, but it was P0300(multiple misfire). So today to start troubleshooting, I swapped out the coil packs(msd to stock) to no avail. Any suggestions on this annoying little problem would be appreciated. Thanks dudes
Old Oct 17, 2010 | 08:41 PM
alanmtz's Avatar
alanmtz
also, where exactly is the ground behind the drivers head on an frc so i can check that. thanks
Old Oct 17, 2010 | 08:50 PM
TN Vette's Avatar
TN Vette
How old are the plug wires? My 2000 Silverado did the same thing and it ended up being the wires were breaking down and not getting the power to the plugs. New spark plug wires corrected it and the rough running and P0300 went away.
Old Oct 17, 2010 | 08:55 PM
alanmtz's Avatar
alanmtz
i wouldnt know how to answer that question since i havent changed them since i got the car:bb maybe i should change them out, but i'd like to troubleshoot the ground connection before i spend some dinero
Old Oct 17, 2010 | 08:56 PM
lucky131969's Avatar
lucky131969
If I'm not mistaken, the P0300 is a "random" misfire....not a "multiple misfire".
As already mentioned....simple stuff first...inspect plugs and wires.
Old Oct 17, 2010 | 09:01 PM
ZZ06's Avatar
ZZ06
Old Oct 17, 2010 | 10:59 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
WTF would you go to an auto store to pull your codes !!!!.
Read your car manual, the system is built in to all C5's to get your codes.
Obtaining Vehicle Codes from the DIC
The IPC display, the 20-character, vacuum florescent screen above the steering column that says "Corvette by Chevrolet" every time you turn on the key, is a powerful device. DIY Service Techs are going to be most interested in the IPC's ability to show diagnostic trouble codes (DTC) for all the modules that transmit them.
The "diagnostic display" mode is entered with the following procedure:
1. Turn on the ignition but don't start the engine.
2. Press the "reset" button to turn off any warning messages
3. Press and hold "options" and
4. While holding "options", press "fuel" four times within a 10-second period.
Inititially, the on-board diagnostics go into the "automatic" mode which shows each module's DTCs in a pre-set sequence:
• 10 PCM Powertrain Control Module page 6-357 - 6-361
• 28 TCS Traction Control system ABS on page 5-86
• ?? RTD Real Time damping page 3-136 (I do not have this option)
• 40 BCM Body Control Module page 8-405 UTD Page 8-727
• 60 IPC Instrument Panel Cluster page 8-508
• 80 radio page 8-213
• 99 HVAC Heater Vent-Air Conditioning page 1-118
• A0 LDCM Left Door Control module page 8-904 to 8-951
• A1 RDCM Right Door Control Module page 8-904 to 8-951
• AC SCM Seat Control module page 8-1064 -8-1082
• B0 RFA Remote Function Actuation page 8-676
For each module, all DTCs will be displayed. If none are present in a module, you will see "no more codes" on the ICP display.
There are two kinds of DTCs, "Current" and "History," designated with a letter suffix, "C" or "H". A current code indicates that the malfunction is present in the system whose module is displaying data. A history code indicates a problem existed in that module sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it is possible it's evidence of a previous problem, now solved, that was not removed by clearing codes. More likely is that a history code indicates an intermittent malfunction. "Intermittents" are the most challenging DTCs. An intermittent may have happened only once, may have happened more than once but is inconsistent in its appearance or may be happening on a regular basis but not at the time the IPC is displaying codes. History codes can also be caused by a current malfunction in a system that is not operating at the time DTCs are displayed. An example is the rear window defogger which doesn¹t operate until the BCM detects engine rpm. For history codes set by a system that does not operate with the key on and engine off, a special diagnostic tool called a "scan tester" is necessary to properly diagnose the malfunction.
Once the IPC has displayed all 11 modules, the system goes into the manual mode which allows selection of each module using combinations of DIC buttons. The manual mode can also be entered at any time during the automatic sequence by pressing any button except "E/M". Once the IPC displays "manual diagnostics," you may select a particular module by pressing the "options" button to go forward or the "trip" button to go back. Once a system is selected and a DTC is displayed, if more than one are present; press "gages" to move forward or "fuel" to go back.
To exit the diagnostic mode at any time, press "E/M". If you want to erase or "clear" codes, press "reset." Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory.
• 10 PCM Powertrain Control Module page 6-357 - 6-361 Domestic
• A=DTC set immediately and MIL is turned on
• B=MIL turned on after 2 consecutive drive trips
• C=After one failure and stored in History MIL not turned on
Old Oct 18, 2010 | 09:25 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
That ground connection on the rear of the driver's side head is the most usual cause of misfires. Its not the only cause. Please check that connection. Its on the back of the head, facing the firewall. Just put your hand back there and you'll feel the wires on a bolt going into the head.
To Multiple misfire
