max hp for a stock A4?
Old Oct 18, 2010 | 08:59 AM
maroman88's Avatar
maroman88
Default max hp for a stock A4?
looking to do some mods this winter, cam and long tubes, wondering how much the stock A4 can handle, car isnt raced often, maybe once a year and has 82k on it
Old Oct 18, 2010 | 01:30 PM
Bluefire's Avatar
Bluefire
The max numbers I have heard tossed around are:
450 hp/350 tq
Old Oct 18, 2010 | 02:05 PM
torchvette10's Avatar
torchvette10
450 hp/350 tq
If you go higher than that, it's better to be ready for a new tranny sooner than later
Old Oct 18, 2010 | 06:37 PM
maroman88's Avatar
maroman88
not baddd, we talkin rwhp or at the flywheel? i think ill be safe either way (for now)
Old Oct 18, 2010 | 07:56 PM
Blow Torch's Avatar
Blow Torch
I was well over 400rwhp (490whp) for over 5 years (running drag radials) with no issues.
I'm close to 700rwhp now but of course I know it's just a matter of time.
Old Oct 18, 2010 | 08:29 PM
motogib1's Avatar
motogib1
I've been running in the 420 rwhp range with a high stall for a good while. It does help to have a tranny cooler if your running a stall. Based on what I had read, I thought mine would bite the dust in no time. Surprisingly it has hung in there through quite a few 1/4 mile runs. Its been thrown around that 400ft-lbs torque is the limit, but the 490 rwhp post is encouraging.
Old Oct 18, 2010 | 08:57 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
I ran 3 years with 550rwhp and 500 torq before replaceing the
tranny. You also will need to replace your driveshaft couplers.
Mine lasted 3 years.
Old Oct 18, 2010 | 09:24 PM
David426's Avatar
David426
A4 is weak.. 320rwhp on my 99 38k miles and it was fried.. Talk to Rodney at RPM.. He will hook you up.. Heat is the killer... Anything over 210 degrees is not good.. Do a couple of hard runs on the highway and see what your tranny temp is... It does not take much to heat up fast... A tranny cooler will help for awhile. RPM Transmissions has made a fortune on Forum members with the A4 transmissions.. Its the weak link in the C5.. A lot of folks claim big numbers on their A4, but you have to remember most of these cars have had several owners and have probably already had an upgraded rebuild somewhere down the line, and the current owners are unaware
To max hp for a stock A4?
