Help with 04 starting
Old Oct 19, 2010 | 10:24 AM
music4lin's Avatar
music4lin
Default Help with 04 starting
There a a few times that my car won't start. When you turn the key all lights on dash come on but it won't turn over. After a min or two it will start but, then goes dead again. After Multiple time of restarting it runs fine. This has happened a few times. Not sure what could be causing this. Any Help?
Old Oct 19, 2010 | 12:32 PM
music4lin's Avatar
music4lin
Default Codes
I pulled the codes and one keeps coming back after I reset it. BCM B-2723.
Old Oct 19, 2010 | 01:33 PM
music4lin's Avatar
music4lin
Thanks. I read about this problem and I have already replaced the ignition switch. I have tried the other key while it's doing this and that doesn't work so I will try the contact cleaner. Thanks for the help.
Old Oct 19, 2010 | 01:50 PM
lucky131969's Avatar
lucky131969
Did you transfer the lock cylinder over from the old switch, or replaced the whole assembly?
Old Oct 19, 2010 | 02:59 PM
music4lin's Avatar
music4lin
Transfered cylinder over to new switch.
Old Oct 31, 2010 | 04:25 PM
music4lin's Avatar
music4lin
Jumped out the VATS . Works great now. If anyone needs help with this PM me and I will tell you how to do this.
To Help with 04 starting
