Another Mobil 1 Question
Old Oct 21, 2010 | 01:58 PM
Vettmann17's Avatar
Vettmann17
Default Another Mobil 1 Question
I'm going to be doing my own oil changes and going to stick with Mobil1. My question is what is the difference between the regular Mobil 1, high milage and extended performance? My 02 has 70K miles on it and was wondering if I should switch to the high milage oil or just stick to the regular formula.
Old Oct 21, 2010 | 02:12 PM
manley845's Avatar
manley845
Uh oh, here we go again
Your best bet is to go to Mobil's website and look up the info on the oils you're interested in.
My basic understanding though, is that the EP has a "better" additive package. My thought is, my owners manual suggests Mobil 1 and a change interval of 1 year or 15k miles, but they do not specify in the manual to use Mobil 1 EP. Hmmm, is it really that much different??? Dunno, but the cost is very similar so I use the EP stuff.
The High Mileage, from my understanding, contains "seal conditioners" that help with old seals.
I'm sure there is more to it than this, but thats what the Manufacturer's website is for.
Old Oct 21, 2010 | 04:37 PM
bobby777's Avatar
bobby777
Go with the new pennzoil synthetic--clean out the build-up in the motor--5-30---
Old Oct 22, 2010 | 11:33 PM
VETLAG72's Avatar
VETLAG72
Mobile 1 EP & High Mileage do not list the GM 4718M spec, standard Mobile 1 does
Old Oct 23, 2010 | 12:08 PM
dbaker's Avatar
dbaker
IMO,the GM 4718M spec is very important.
Use oil that meets it.
\db2
carolina
Old Oct 23, 2010 | 12:13 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
what build up?
just looked at an LS1 with over 100K on it always used Mobil 1....there was no build up
Old Oct 23, 2010 | 04:06 PM
AU N EGL's Avatar
AU N EGL
Build up? that is in cars that are not driven hard.
Old Oct 23, 2010 | 04:10 PM
Z06supercharged's Avatar
Z06supercharged
If there was ONE oil that was superior to all the others then EVERYONE would be using that one brand oil because the tests would show it superior to all the others.
There isnt....
Use whatever makes you happy.
Old Oct 23, 2010 | 04:19 PM
VETLAG72's Avatar
VETLAG72
There isnt....
I do personally feel more comfortable if it meets the GM 4718M spec, but beyond that I think the main concern should be changing at the recommended intervals from the factory and you're good
Old Oct 23, 2010 | 04:46 PM
pewter99's Avatar
pewter99
There isnt....
Probably not.... it has been proven time and time again you can go by the OLM yet we have people who change their oil every 3000 miles...
To Another Mobil 1 Question
