Engine Light flashing
Old Oct 22, 2010 | 09:04 AM
1-waterman-1's Avatar
1-waterman-1
Cruising
Default Engine Light flashing
I just purchased a 2001 with 5k miles, 6 speed, I had driven about 45 minuted at highway speeds, When I got to town I parked the car, when I started the car the engine missed at low speed, I continued in town, while driving, the engine check light started flashing (engine missing ) I stoped the car and after about 1 hour started the car and all was ok, When I got home I pulled the codes U1000H and U1064H Anyone know what is wrong ? The car runs great now.
Old Oct 22, 2010 | 10:39 AM
KENCO's Avatar
KENCO
St. Jude Donor '11
U1000 Loss of Communication Undetermined
U1064 Loss of Communication with BCM
H means History
Old Oct 22, 2010 | 01:40 PM
robsc501's Avatar
robsc501
Hi There,
Those codes indicate a low battery or loose or corroded cables. Check your cables & then check the voltage with dmm between the positve & negative terminals of your battery. If your reading in 12.20's then put the charger on until you are above 12.50 & then delete the codes & then post up the current codes.Auto zone can clear the ECL
robsc501
Old Oct 22, 2010 | 01:43 PM
hotwheels57's Avatar
hotwheels57
For future reference...
http://www.stengel.net/diccodes.htm
Many C5 codes are related to a poorly performing battery (or grounds). Once the battery is charged or replaced, the codes may disappear.
Wait until you get the codes from failing to ratchet the fuel cap properly or reset the oil life monitor after an oil change. Those get a lot of new owners (me included).
Old Oct 22, 2010 | 03:57 PM
KENCO's Avatar
KENCO
St. Jude Donor '11
You are right about those ground points! There are about a biz-zillion of them, especially check those in the front of the engine compartment, they attached to the frame with a cheap plastic connector.
RX-Ben's Avatar
RX-Ben
The blinking CEL is the missing code. There is no sep code that is posted. I had this problem after installing new wires (MSD). A few were touching some of the AIR components. The red plug wires had some black spots where there was touching - I wrapped some 3/8" rubber fuel hose around the wires that were touching and have had no problems since.
This missing only occurred on the track, I assume it had something to do w/the wire temps.
Old Oct 22, 2010 | 04:23 PM
dougbfresh's Avatar
dougbfresh
Typically flashing CEL is random misfire codes, P0300 or P030x where x is the cylinder #.
Old Oct 22, 2010 | 04:25 PM
RX-Ben's Avatar
RX-Ben
Interesting. I didn't get any codes and was about as fast as a Miata on the straights.
Old Oct 22, 2010 | 04:38 PM
dougbfresh's Avatar
dougbfresh
The P030x's will not read out on the DIC only the P0300.
Old Oct 22, 2010 | 05:59 PM
1-waterman-1
Cruising
Thanks, I have a new battery, and I have checked the grounds on both sides of the frame, Couldn't see any other grounds from looking from the top of engine. I also just changed oil and filter and reset the millage, I have MSD coils, I did notice that the third spark plug wire on the driver side had some rub marks on the plug wire, maybe that is it.
Thanks,
Old Oct 22, 2010 | 06:02 PM
lucky131969's Avatar
lucky131969
Thanks,
Also note that, unlike factory coils, MSD coils do have a history of going bad.
Old Oct 22, 2010 | 06:05 PM
1-waterman-1
Cruising
I was wondering why the previous owner replaced the coils to begin with !
Old Oct 23, 2010 | 08:59 AM
Jewjenk's Avatar
Jewjenk
Yep, especially at 5k miles, was this possible a flood damage car?
Old Oct 24, 2010 | 08:35 AM
1-waterman-1
Cruising
Sorry, That should be 50k. I have 3 MSD coils that have expanded where the red casing is put togather, I have not been able to contact MSD to get some testing specs. Anyone know how to test the coils ? and should I go back with a set of GM coils ? The codes were in the BO-RFA, No other codes listed.
Old Oct 25, 2010 | 09:40 AM
1-waterman-1
Cruising
When I pulled the codes I used the dash readout in the car, If I used a scanner code reader would I get more codes ?
To Engine Light flashing
