e-brake issues
Old Oct 22, 2010 | 10:55 AM
2001_STL_c5's Avatar
2001_STL_c5
Default e-brake issues
Awhile back my car was hit and I had it towed. Long story short, the genius that towed my car put the e-brake on while he towed it and since then the handle won't stay up if I pull it...like all the teeth that would normally click in place until you press the release button are broken off or something. The brakes do work when I pull it (tested that out while rolling slow in a parking lot) it just won't lock in place. Of course the tow company is saying its not their problem so I need to fix it on my own. Anyone have ideas of where I should start? Not sure where to start to figure out what I need to get to fix it.
Old Oct 22, 2010 | 10:58 AM
dougbfresh's Avatar
dougbfresh
Pull the rear rotors and take a peek at the e-brake.
Old Oct 22, 2010 | 11:02 AM
2001_STL_c5
Even though the braking is still working when pulled? The handle just won't stay up?
Old Oct 22, 2010 | 11:19 AM
dougbfresh's Avatar
dougbfresh
Then open the console up and check out the E-brake handle-probably stripped the teeth or the tang that holds it in place.
Old Oct 22, 2010 | 11:36 AM
SDPC's Avatar
0SDPC
Former Vendor
The clicking and locking is all handled on the interior of the car. Pull your console and look it over, any problem will likely be obvious
Old Oct 22, 2010 | 02:52 PM
hunterhicks's Avatar
hunterhicks
This may help. It's funny, it's been so long since I did this, I don't remember if the symptoms were exactly like yours or not!
Check to see if the emergency brake button is sticking out further than usual from the handle (I mean a very small difference, maybe a 1/4 of an inch.) That's what I noticed, and here is the fix.
http://forums.corvetteforum.com/c5-t...f-problem.html
To e-brake issues
