Thermostat Change
Old Oct 22, 2010 | 09:54 PM
WilliamCall's Avatar
WilliamCall
Default Thermostat Change
I'm about to replace the OEM thermostat with a 160 degree thermostat. Thought I'd check the GM maintenance manual before I start turning a wrench. The manual states that the thermostat AND housing should be replaced as a single unit. What's up with that? I don't see the need to replace the housing. Does anybody know the rationale for this? Thanks!
Old Oct 22, 2010 | 11:14 PM
warren s's Avatar
warren s
The 97 to 03 all have the t-stat built into the goose neck / housing.
In 04 it was a separate t-stat and housing. No need to change the housing on an 04.
Old Oct 22, 2010 | 11:21 PM
MTPZ06's Avatar
MTPZ06
That's just the way it is...and yes, it doesn't make sense. I suppose that's why they changed it.
Old Oct 23, 2010 | 09:17 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
What doesnt make sence is why would you want to change to a 160 stat Now, with winter coming in MD.? This is the time when most 160 stat users in the North east go back to a stock stat. Not a real smart idea to be running engine oil below 200 F in an LSX engine, which is what will happen with a 160 stat and winter driving in Maryland.
To Thermostat Change
