O2 Sensor Help
Old Oct 24, 2010 | 03:26 PM
Tulsa Vette Guy's Avatar
Tulsa Vette Guy
Default O2 Sensor Help
What is the hottest O2 Sensor for LG long tube headers,, The right side (only one sensor) can you buy, I am still having check engine light come on, 1133,, I put a Denso in and no help. Any help on this problem.
Old Oct 24, 2010 | 03:45 PM
Russ K's Avatar
Russ K
You will need to delete the insufficient switching codes when LT headers are installed. Also usually the slow response codes will need to be deleted.
http://forums.corvetteforum.com/c5-s...t-go-away.html
Russ Kemp
Old Oct 24, 2010 | 04:19 PM
Tulsa Vette Guy
There is a problem, I would prefer to fix it Right if possible.
Old Oct 24, 2010 | 04:24 PM
Russ K's Avatar
Russ K
Been tuning for a long time, that is the correct way to correct your codes. As that thread shows, people have replaced & tried different O2 sensors without fixing the codes.
Russ Kemp
To O2 Sensor Help
