Where can I get diff seals?
Old Oct 24, 2010 | 04:19 PM
chrisbenoit's Avatar
chrisbenoit
Default Where can I get diff seals?
I have the trans and diff out of my FRC. I had a slight leak before removing it to do my clutch over. Where can I but the seals on both sides of the diff? One is a o-ring and other is a lip seal. Also I want to replace the lip seal on the output shaft of the trans and the o-ring between the diff and trans at the same time. Do I have to go to GM to get all these?
Old Oct 24, 2010 | 05:12 PM
sami85L98's Avatar
sami85L98
get from GM deale or rpmtransmissions.com they are vendors here as well, will sell prolly as seal package deal.
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Gene Culley at www.GMPartshouse.com
Old Oct 28, 2010 | 04:07 PM
chrisbenoit
Does anybody have a part number for the 2 oil seals on the output shaft of the transmission where it bolts to the diff? Can't seem to find a part number anywhere? Thanks.
Old Oct 28, 2010 | 05:55 PM
81c3's Avatar
81c3
Mine were for my 02 Z06, Not sure if every one is the same, but I assume so.
Pt# 88996703
Old Oct 28, 2010 | 07:14 PM
ragtopws6's Avatar
ragtopws6
Look here for the seals and o rings.
12369456
Old Oct 28, 2010 | 09:31 PM
chrisbenoit
I have the numbers for the Diff seals and O-rings. I now need the 2 seals on the output shaft of the transmission that fit in the transmission tail housing. The 2 seals are regular oil lip seals that are back-to-back to keep the tranny and diff fluids from mixing.
Old Oct 28, 2010 | 09:49 PM
ragtopws6's Avatar
ragtopws6
Are you replacing the seals with the tail shaft housing on the trans? If so, you'll need a seal driver that goes over the output shaft (Kent Moore J-42198) to install them correctly. I'll get you the part #'s tomorrow.
Old Oct 29, 2010 | 05:29 AM
chrisbenoit
That is exactly what I need. I would greatly appreciate the part numbers of the seals is you could give them to me. Thanks
Old Oct 29, 2010 | 10:33 AM
ragtopws6's Avatar
ragtopws6
Inner seal # 19206242
Outer seal # 12455045
Old Oct 29, 2010 | 09:18 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thanks for the referrals. I would be happy to help anyone out!
To Where can I get diff seals?
