Check Engine light won't come on
Old Oct 25, 2010 | 02:02 PM
whtcorv2k's Avatar
whtcorv2k
Default Check Engine light won't come on
My 2000 C5 will not turn on its' check engine light, even during initial checkout when you first turn the key. There are no codes so nothing is wrong except that the light won't come on so it won't pass state inspection. I recently had a new 'after market' Pioneer stereo installed. Is it a coincidence or do you think that the two things could be related? (And I have to pass inspection before I can renew my registration.)
Old Oct 25, 2010 | 02:40 PM
PEERPSI's Avatar
PEERPSI
Burnt out light bulb?
Old Oct 25, 2010 | 02:49 PM
westez's Avatar
westez
You're lucky, most people can not get it to go off.......
Old Oct 25, 2010 | 02:54 PM
m6 c5's Avatar
m6 c5
I dont see why it wont pass with it not on, maybe they are different where you live or the shop is really picky. But I know several people who have unplugged their light so that it would pass which means it wont come on at start up. I also know some people have passed with their light on.
Old Oct 25, 2010 | 02:55 PM
whtcorv2k's Avatar
whtcorv2k
I talked to the local Chevy dealer and they said they didn't think there was a light bulb for the check engine light. They think it is part of the cluster and those light don't usually go out. Sounds kinda like guessing to me. It would be great if I could find that it is just a light bulb but apparently you have to take the dash apart?
Old Oct 25, 2010 | 02:57 PM
whtcorv2k's Avatar
whtcorv2k
Right, my neighbor has an 84 model where the light won't go off and his passes (we're in NC). But on the 2000 model, the rules say it must work.
Old Oct 25, 2010 | 03:01 PM
m6 c5's Avatar
m6 c5
Well the guy I know that unplugged his light has a 04 mustang gt if Im not mistaken and he passes here in Virginia. And my gf's honda's light was on when she got it inspected at it passed this past year.
Have you tried to take it in and see if it passes?
Old Oct 25, 2010 | 03:06 PM
dougbfresh's Avatar
dougbfresh
In Illinois, the light HAS to go on during startup or it will FAIL emissions.
Old Oct 25, 2010 | 03:14 PM
whtcorv2k's Avatar
whtcorv2k
Yes, it was during the inspection that I found out the check engine light was not working and it failed the NC inspection because of it. I guess the rules are a little different in Virginia. And I don't know when it stopped working. That's why I suspect it may have something to do with the installation of the new stereo because it has GPS, touch screen, etc. so there are a lot of wires involved. I was wondering if anyone has seen the installation of a stereo cause something like the check engine to stop working? Maybe a ground issue or something? I hate to have someone tear my dash apart only to find out it has something to do with the stereo.
Old Oct 25, 2010 | 03:20 PM
m6 c5's Avatar
m6 c5
My guess would be that it is just your light that is burnt out but Im not expert and form what I understand its not too hard to pull the gauge cluster out of the car.
Maybe you could try to find a more lenient shop to inspect your car.
Old Oct 25, 2010 | 03:36 PM
whtcorv2k's Avatar
whtcorv2k
It's interesting that one dealership said there was a light bulb behind there and one said it was part of the cluster. Sure would be nice if they were a little more familiar with their product. Does anyone know for sure what the 2000 C5 uses for the check engine light? Thanks.
Old Oct 25, 2010 | 04:21 PM
m6 c5's Avatar
m6 c5
I just finished looking at the service manual and it does not indicate a bulb for replacing anything on the cluster but that doesnt mean there isnt one.
Also Im a little out of practice on reading electrical diagrams but it appears that the check engine light has a lead going directly to the fuse box under the hood and form there running to a separate relay.
Old Oct 25, 2010 | 04:25 PM
Nver2loud's Avatar
Nver2loud
I have an old cluster in my garage...I will look at it when I get home.
Old Oct 25, 2010 | 07:33 PM
PEERPSI's Avatar
PEERPSI
It's a light bulb. PM an email address and I'll send you the schematic.
Old Oct 25, 2010 | 10:57 PM
whtcorv2k's Avatar
whtcorv2k
That's really good information, thanks very much. The folks who installed the new stereo are back from vacation in the next couple of days and I can give them this information and see if that sounds like something they may have encountered during installation.
Old Oct 25, 2010 | 11:00 PM
whtcorv2k's Avatar
whtcorv2k
That would be great! PMed my email.
Thanks very much!
Last edited by whtcorv2k; Oct 26, 2010 at 08:24 AM. Reason: Removed email and sent in PM
Old Oct 25, 2010 | 11:01 PM
whtcorv2k's Avatar
whtcorv2k
Thank you!
To Check Engine light won't come on
Old Oct 25, 2010 | 11:04 PM
m6 c5's Avatar
m6 c5
Just to let you know you may want to just send peerpsi your email address in a personals message(pm) so that the general public cant see it.
To send him a pm just click on his name then click on send private message to peerpsi.
Just a thought to keep you form getting a lot of spam email.
Old Oct 26, 2010 | 06:20 AM
PEERPSI's Avatar
PEERPSI
Looking at the schematic it's doubtful that the stereo install had anything to do with it. I'm at work now but when I get home I can email the schematic to you. My opinion is you will be needing to pull the console and change the bulb. If it's not something you're comfortable with you may want to look for a GM dealer that has a clue.
Old Oct 26, 2010 | 09:08 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I believe the lamp is a standard 194 and it connects via the circuitry on the rear of the IP Cluster therefore a stereo installation should not have anything to do with it. You'll need to remove the cluster to get to the lamp. Its not that hard. You'll need to remove the center console, then the surround for the IP Cluster, knee bolster and etc. Remove the large nuts holding the steering column up in place which will allow it to lower about an inch or so which is just enough to clear the steering wheel. You can then unplug the connector on the left rear side of it. Second small ribbon connector at the top for the HUD if you are equipped with a HUD. Once out, keep the IP Cluster standing up in its normal position as the gauges are fluid filled. If you replace the one lamp, replace them all in there...there are only a few.
