Why MSD wires suck
Old Oct 25, 2010 | 02:06 PM
RX-Ben's Avatar
RX-Ben
Default Why MSD wires suck
Car: 2001 base model, stock drivetrain.
The MSD boots get hot and crack, leading to a misfire. The boots are also poorly chosen as they for the wires to contact the AIR tubing in a number of places.
GMPP wires had no such issues and I'll be going back to those.
Old Oct 25, 2010 | 02:10 PM
lucky131969's Avatar
lucky131969
Just wait till 99blancoss sees this thread.......you're in trouble...
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Absolutely---- AND on the coil end--the MSD boot inner diameter is too thick-- and the boots will pop off as they don't "snap" on when installed-- GMPP or i like the Taylor T-50 thundervolts---Running them now for 5 years with LT headers and NO issues------
Old Oct 25, 2010 | 02:17 PM
dougbfresh's Avatar
dougbfresh
Seems like most MSD stuff stinks anymore.
Old Oct 25, 2010 | 03:35 PM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
Why users make products look bad. Improper installation.
Those boots are multi angle all you needed to do what bend them away from the air tube or primary.
Don't blame the product for customer mis-use, any wire will burn if you lay it on a hot pipe. MSD will last longer being abused as well due to the hi heat silicone, the gm wire and taylor dry out quicker... I've been doing this for a while, I wouldnt push it as a better product unless it was.
MSD is one of the very best on the market, I've never burnt a properly installed wire and neither have my customers.
But the Taylor wires and gm wires are famous for breaking internally where the MSD wont.
Look at the boots in question... looks like someone was gnawing on them, that is not the products fault at all one single bit.
Old Oct 25, 2010 | 03:36 PM
99blancoss's Avatar
099blancoss
Former Vendor
Parts can't install themselves
Old Oct 25, 2010 | 03:37 PM
99blancoss's Avatar
099blancoss
Former Vendor
again improper installation.
I hang my coil end out just a bit farther to help people install them properly
Old Oct 25, 2010 | 03:42 PM
YeloFevr's Avatar
YeloFevr
Mine click right into place and don't touch my headers at all. Maybe they don't conduct as well as GM reds, but I haven't had any issues with mine...
Old Oct 25, 2010 | 03:44 PM
99blancoss's Avatar
099blancoss
Former Vendor
Sorry to correct you but they conduct better than gm wires. Gm ohm out at like 300 and the MSD has 40....
The MSD 8.5mm supercondcutor wire is a better product all the way around, hand down.
Old Oct 25, 2010 | 03:50 PM
YeloFevr's Avatar
YeloFevr
Also, did the OP reuse the factory shields?
Old Oct 25, 2010 | 03:59 PM
BrentC5Z's Avatar
BrentC5Z
I also use Chris' MSD wires with stock manifolds. There is tons of room & I'm not running the stock heat shields. That being said, these look to be burnt way closer to the head where the boots don't have adjustability.
Old Oct 25, 2010 | 04:26 PM
memphis_vette's Avatar
memphis_vette
no problems with my MSD's
Old Oct 25, 2010 | 04:58 PM
Tech's Avatar
Tech
I vote for installer error too. I've had 3-4 sets on my cars and installed them on at least a half dozen other cars. I've had my current set off/on no less than 4 times. I always gently bend (or rotate) the wires away from heat sources and have never had a failure.
Old Oct 25, 2010 | 05:03 PM
Jon@Texas-Speed's Avatar
0Jon@Texas-Speed
Former Vendor
Looks like the wires were probably a little close to the headers. they can be setup where this won't be an issue. MSD is probably some of the better wires out. You can get brand new sets of other brands where the wires break as soon as you put them on and try to take them back off.
I would say a little adjustment will fix your problems.
Jon
Old Oct 25, 2010 | 05:08 PM
FKING1's Avatar
FKING1
Installed properly and not close to headers, 2 cracked.
Old Oct 25, 2010 | 05:23 PM
99blancoss's Avatar
099blancoss
Former Vendor
The boots got compromised, look at the ones that aren't burnt. What caused them to wear like that? That did not dry out and crack it got worn through and then arced out.
I've yet to see a boot legitimately dry out and crack, the boots gets compromised somehow and then the issues arise.
There are some FI applications that generate excess heat and in some of those cases a special hi heat boot is needed and MSD does make them but 99.9% of the time the regular MSD boot suffices.
Old Oct 25, 2010 | 05:29 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I change wires every 10k miles and have tried them all over the years.
Currently I make my own wires since I've relocated coils on this car and my last.
I prefer the Taylor wires over MSD in kit form.
If I had the stock-style setup I'd choose the GM reds everytime. Very well made and have never had an issue.
To Why MSD wires suck
Old Oct 25, 2010 | 05:40 PM
99blancoss's Avatar
099blancoss
Former Vendor
Josh the Taylor terminals are inferior to the MSD, been proved many times over. To each his own I always say but I do like to present facts where it is warranted. I've made and repaired Taylors, Morosso, you name it I've seen just about all of them and repaired them.
The MSD are a better wire. The Taylor's would be better if they had the MSD terminals but the 10.4 is really too thick and doesn't like to be manipulated, is very heavy as well which will eventually cause issues too. The 7mm is a joke really, just a cheap alternative like the Street wires from MSD. GM aren't bad until you have to change them and then break internally wiggling it to get it off. The MSD wont break like that and has lower resistance which brings us right back to square one...LOL MSD 8.5mm Superconductor is the better wire.
Old Oct 25, 2010 | 06:09 PM
imavettegirl's Avatar
imavettegirl
no problems with my MSD's.
Old Oct 25, 2010 | 06:35 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Tell you what...
Since my engine is going back together next week and the supercharger is being added, I'll give the MSDs another go-'round.
Next week will be a major spending spree for stuff needed, if you can get me a good deal on a set of BLACK MSDs (not happy that msd charges extra for non-red color) with the coil ends needed I'll get them from you.
I don't want ugly socks since the engine is 100% polished and all wiring hidden/minimized, so if you think there will be a problem let me know... The Taylors stood up great on my last front mount twin turbo build.
