LS1 vs LS6 ROCKER ARMS
Old Oct 28, 2010 | 11:48 PM
T-TOP TOM's Avatar
T-TOP TOM
Default LS1 vs LS6 ROCKER ARMS
I looked in search and didn't find the answer. Is there any difference between LS1 and LS6 rocker arms? Thanks
Old Oct 28, 2010 | 11:49 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
99.99999999% sure they are the same.
Old Oct 29, 2010 | 03:39 AM
T-TOP TOM's Avatar
T-TOP TOM
Thanks, That is what I thought but wasn't sure.
Old Oct 29, 2010 | 06:32 AM
lucky131969's Avatar
lucky131969
Yes and no. There was a running change made, to improve the bearing design(to keep the needle bearings from working their way out).
Old Oct 29, 2010 | 09:33 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
....and for those with the older design rockers, Comp Cams makes a nifty kit to upgrade the OE rockers. It's #13702-KIT. I installed this kit in my car this past summer, not because I had a problem, but in order to prevent a problem in the future.
Old Oct 29, 2010 | 01:00 PM
Monte04ss's Avatar
Monte04ss
I also had the same kit installed last month when the H/C went in.
Upon the strong recomendation from the Tuner.
Old Oct 29, 2010 | 01:05 PM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
The Comp Rocker Arm Trunion Upgrade is a wise investment
http://forums.corvetteforum.com/c5-t...ith-labor.html
Seth
To LS1 vs LS6 ROCKER ARMS
