whistle noise
Old Oct 29, 2010 | 06:31 AM
brainstorm's Avatar
brainstorm
Default whistle noise
What can be the fault?
I heare a whistling noise when i accelerate.
in the movie i just push the accelerator down 1 cm and then up 1 cm......
http://www.youtube.com/watch?v=yQyv9eQ3YPA
Edit: i think i now what it can be now. Read another thread. it started after i had left the car to change the Oil Pressure Sending Unit, and they had to repair that vacum line because my one was broken or to short (cant remember).
"I had the same exact problem. The whistle is coming off a vacuum line coming off the back of the manifold. The only way to get to it is to take off the intake manifold. I suggest adding some vacuum line to the stock line so you can give it a little play as the stock line is pretty tight and can rip out easy. Good luck."
