loose suspension
Old Oct 29, 2010 | 03:06 PM
jetmech09's Avatar
jetmech09
Default loose suspension
01 vette: when I lift off the throtlle, the nose of the car shifts to the right and the rear to the left. normal driving otherwise. tire wear normal. steering wheel centered.
Old Oct 29, 2010 | 03:17 PM
Dope's Avatar
Dope
Resident moron
Sounds exciting!
Dope
Old Oct 29, 2010 | 03:21 PM
jetmech09's Avatar
jetmech09
yeah it is lol
Old Oct 29, 2010 | 04:46 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I would first be thinking myself of a bad shock(s). How many miles on them at this time? Have you checked them manually by pressing down and suddenly releasing the side of the car for each shock? Leaking shocks? Usually shocks or alignment can cause the car to wobble. There are lots of other possibilities too.
Old Oct 29, 2010 | 05:46 PM
jetmech09's Avatar
jetmech09
will check shocks and also have car realigned. thanks.
Old Oct 29, 2010 | 05:58 PM
Its_Go_Time's Avatar
Its_Go_Time
What does it do when you get on the gas hard? Maybe the rear wheels don't point perfectly fwd...your "thrust line" might need to be tweaked. My front suspension loosened up on me once (lower control arm cam bolt), and it's pretty unmistakable. That wheel would toe out every time I touched the brakes, sending the car into the next lane and activating the active handling system. Those cam bolts need to be TIGHT...
Old Oct 29, 2010 | 07:02 PM
dgrant3830's Avatar
dgrant3830
It does sound like the rear wheels are out of alignment...
To loose suspension
