Coolant change question
Old Nov 1, 2010 | 12:43 AM
CaliforniaJack's Avatar
CaliforniaJack
Default Coolant change question
I changed the coolant again and carefully measured the amount of old coolant that drained out. I measured only 8.7 quarts after jacking the rear up and removing the thermostat. The manual says the coolant capacity is 12,6 quarts. This means 30% (3.9/12.6) of the old coolant was retained after a "complete" drain. How do you get more old coolant out. I know I could do repeated flushes with water, but then I'd have many gallons of contaminated water to dispose of. There has to be a better way. What is it?
Old Nov 1, 2010 | 03:54 AM
carnut101's Avatar
carnut101
I wouldn't be worried about it, the remaining fluid is factored into the service intervals. Same happens with your motor oil and transmission fluid.
Old Nov 2, 2010 | 08:30 PM
CaliforniaJack
I don't have 30% of the old oil in the engine or 30% of the old fluid in the trans after I change them. I filled my engine with oil starting dry (after a rebuild) and it took LESS than 1/4 quart more than a normal oil change so at LEAST 6/61/4 (>96%) of the old oil comes out (if you jack up the rear and let it drain awhile) I'll bet the trans fluid (manual trans) drain efficiency is about the same. A mixture of 30% old coolant plus 70% new fluid is equivalent to a complete change of new fluid after 1 1/2 years. That's NOT efficient.
Old Nov 2, 2010 | 08:34 PM
Bill Dearborn's Avatar
Bill Dearborn
I flush/refill with water/flush the engine a couple of times until the water coming from the drain runs clear. Then I add in the proper amount of coolant to get a 50/50 mix and top off with water. You will get about 4 gallons of waste fluid.
Bill
Old Nov 3, 2010 | 10:38 PM
ALLEGRO's Avatar
ALLEGRO
Bill
Old Nov 3, 2010 | 11:15 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
So?
Just do it more often.
Old Nov 4, 2010 | 01:11 PM
Oldvetter's Avatar
Oldvetter
The most fluid will come out when the car is level, if left on the ground, you must use a thin drain pan and empty it often. You should get all but 1 0r 2 quarts out.
Old Nov 6, 2010 | 09:49 AM
Swayse's Avatar
Swayse
Flush doesn't really work for us guys with super hard water. I could use water out of my home water softener, but I've heard that it's not a good idea either. I like to buy premixed coolant.
Old Nov 6, 2010 | 10:54 AM
STL94LT1's Avatar
STL94LT1
I distilled water, less than a buck a gallon.
To Coolant change question
