I was really ticked when my hydraulic 228/232 cam failed to make the smog test on my LS7 block 427 in my 2002 Z. I loved the combination, but Kalifornia did not. 501rwhp/528rwt
Remembering my old C3 days, the mild hydraulic cams had durations very close to the hot mechanical cams of the day.
Question: What if I were to run a similar grind solid roller and replace the lifters at smog test time with hydraulic lifters? Would this make the cam "smaller" allowing for a better chance of passing smog?
This process would be repeated every two years and removing the intake to access the lifters is pretty easy. I could even rotate a set of solid lifters rebuilding one set at $12 each after each cycle.
An all aluminum engine does not need hot lash like an iron engine, lash grows as engine gets hotter, so I could even preload the solid to obtain .001" at normal idle temp. There would be very little rattle to cause wear on parts.
Genuine expertise would be greatly appreciated!
Reason: clarification
Or maybe just GTH outta The People's Republik of Kalifornia.
Don't tell him that! We have too many Californians that've moved up north, already. J/K, I'm just jealous that they can sell their houses in CA. move north, and pay cash for a house, and start a business for what profit they got out of their CA. house.
You failed with that cam? That's shocking to me. Were the cats hot enough? I had a 228/232 cam (on a 115lsa) and it passed CA smog. The thing with the sniffer here is overlap. 0 or negative overlap will usually pass if the car is tuned well. The Katech toquer cam on a 116LSA should pass. Andy (A&A Corvettes) has some LS7 cams that will pass also.
