Shifter locks in park
Old Nov 3, 2010 | 05:02 PM
George Hubert's Avatar
George Hubert
Default Shifter locks in park
My 98 Vert A4 locks in park at times, this morning I tried turning the key on and off starting and stopping the engine. Pressing the foot brake hard hard. Pressing the button on the top of the shift hard, soft etc. Finally with no apparent reason it finally allowed me to shift out of park. This has happened on and off for several months. any ideas????
Thanks George
Old Nov 4, 2010 | 02:52 AM
egrand333's Avatar
egrand333
Mine has done this also. There was a write-up about this problem a few weeks ago. There is a part below the shifter that prevents it from being moved out of park without putting pressure on the brake pedal. The advice was to replace or unplug it.
Old Nov 4, 2010 | 01:21 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You need to remove the console and investigate the brake before shift cable and mechanism.
BC
Old Nov 8, 2010 | 06:34 PM
seattle's Avatar
seattle
My 98 had the same problem. There is a solenoid in the console that is sticking. This is the solenoid that requires you to step on the brake pedal before you can shift the A4 into gear. I did a search on this and found out how to unplug the solenoid. No problem ever since.
To Shifter locks in park
