Problems starting (HELP!)
Old Nov 7, 2010 | 03:16 PM
jetstreamC5's Avatar
jetstreamC5
Default Problems starting (HELP!)
Ok I put a used BCM in my car about a month ago that has all the same options as my car done the whole reprogram thing it started up and everything was fine for a while. Here lately ive been having trouble trying to get it to start you turn the key and you can here the BCM fire up but it wont crank over unless you just hold the key to the start possition for a minute then it will crank rite up. This happens somtimes 2 or 3 times a day somtimes it will be fine a couple of days any suggestions.
Thanks,
Michael
