one click no start
Old Nov 8, 2010 | 06:28 PM
wagner262's Avatar
wagner262
Default one click no start
DTC B1001 Option Configuration Error
DTC C1221 LF Wheel Speed Sensor Input Signal is 0
DTC C1225 LF Excessive Wheel Speed Variation
DTC C1232 LF Wheel Speed Circuit Open or Shorted
DTC C1291 Open Brake Lamp Switch Contacts During Deceleration
DTC C1293 DTC C1291/C1292 Set in Current or Previous Ignition Cycle
DTC U1096 Loss of Communications with IPC
DTC U1016 Loss of Communications with PCM
DTC u1016 Loss Of PCM Communications
DTC u1064 Loss Of BCM Serial Data Communication
i pulled these codes.
my car isnt starting it does the one click and doesnt even turn over. the starter was recently replaced. i wanna say its the battery but all the lights/radio all works when i turn the ignition on. i dont think i could be an alternator if my battery still have juice..
what could it be that my car wont start? could it be a loose wire or something?
Old Nov 8, 2010 | 09:48 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree with 8Vette7 totally. If you find all those connections clean and tight, its very possible that your starter solenoid has died in which case, use a mallet on it and see it the car will start. If so, then you need a new solenoid.
Old Nov 8, 2010 | 10:47 PM
wagner262's Avatar
wagner262
yeah i just talked to my friends dad (head mechanic at a gm dealership) he mentioned both check the connection and tap siloniod (spell) do you tap it with someone pushing clutch i think he said right? and try starting as you tap?
so i bought a new battery and unfortunatly looks like its probably the starter or silinoid. im just hoping its not a tiny wire somewhere that takes a lot of time and knowledge that i dont have lol
Old Nov 9, 2010 | 08:35 AM
dgrant3830's Avatar
dgrant3830
I would clear those codes first and see if any return. Specifically look for the "H" or "C" characters with the codes. The no comms with the PCM and BCM and the BCM 1001 are issues that need to be looked at. Back on the single click, I was assuming you are referring to a single loud click as if coming from the solenoid. If so, then you've got a bad solenoid or really low battery, bad battery connection or etc...
Old Nov 9, 2010 | 06:12 PM
robsc501's Avatar
robsc501
Hi There,
Well one more shot at guess work (batt.& starter) will not hurt.Change your starter solenoid that was the problem to begin with.Clutch engaged & tap on it with a hammer. If it does turn over replace the s/ solenoid. You should be reading 12v at the s/solenoid wire.
robsc501
Old Nov 9, 2010 | 07:27 PM
egrand333's Avatar
egrand333
My son had the "one click" problem over the weekend with his 99. He replaced the starter today and problem gone.
Old Nov 10, 2010 | 07:24 AM
99 vett babycar's Avatar
99 vett babycar
this has happened to me twice over the past 11 years - both times it was the battery, even though both times the battery "tested" good.
Old Nov 10, 2010 | 12:30 PM
wagner262's Avatar
wagner262
thanks guys i appriciate the help!
so i did replace the battery, decided to call the local gm dealer to see what they charge because im very busy. $400! are you kidding me lol
any ways i asked if i could just replace the seliniod and not the starter and thought i was stupid like you cant do that? ive never really messsed with a starter in general. is the seliniod typically connected or apart of the starter?
Old Nov 10, 2010 | 12:51 PM
egrand333's Avatar
egrand333
I don't think you can buy the solenoid seperately, although I saw a post a while back about C5 starters and someone (Bill Curlee?) said that they were able to get one at some kind of electronics place. By the way, if you have to drop the exhaust, break rusty studs,etc. and depending on your mileage, you may want to just replace the starter too. Yes, you used to be able to buy the solenoids seperately for most starters.
Old Nov 11, 2010 | 08:46 PM
wagner262's Avatar
wagner262
thanks again guys!
found out it was a loose wire on the selinoid on top!
but still think i need a new starter eventually along with an alternator
To one click no start
