visual differences - ls1 /ls6 C5 intakes
Old Nov 10, 2010 | 10:59 PM
trophy hunter's Avatar
trophy hunter
Default visual differences - ls1 /ls6 C5 intakes
Are there any visual "ques" / differences between the C5 LS1 and LS6 intakes when installed ?
Old Nov 11, 2010 | 06:37 AM
lucky131969's Avatar
lucky131969
Only if you are comparing the part number, which will be different on a 97-2000, compared to a 2001-2004. There is no "LS6" intake manifold, as the LS1 and LS6 used the same manifold starting in 2001.
Old Nov 11, 2010 | 03:01 PM
trophy hunter
So there are no visual differences between the 97-00 and the 01-04 ?
Old Nov 11, 2010 | 03:25 PM
MG RED 99's Avatar
MG RED 99
The only visual differences are on the bottom side of the 2 different style intakes. The 01-04 has ribs along the bottom, and slightly deeper which interfere with the coolant crossover tubes for guys who change out their 97-00 style manifolds. Some guys remove the tubes or remove some of the ribs when changing over to the newer style. This isn't visible once installed on the car though. Sorry I don't have any photos. Try doing a search for comparisons between the two.
Old Nov 12, 2010 | 06:48 AM
lucky131969
I agree; however, the OP asked about as installed:
....which just leaves the molded part number....that is visible.
Old Nov 12, 2010 | 10:09 AM
MG RED 99's Avatar
MG RED 99
[QUOTE=lucky131969;1575903655]I agree; however, the OP asked about as installed:
Old Nov 12, 2010 | 01:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
HELL YES there is and I can show you this real QUICK!
Heres a LS1 97-2000 intake. Look at the bottom. If it looks like this,,, it an LS1 97-2000:
If the bottom to the manifold is FLAT,, it a late model ZO6 style. :
BC (in SUNNY HOT Bahrain!!
Old Nov 12, 2010 | 03:28 PM
kmetros's Avatar
kmetros
The part number is molded on the face/top side in between a couple of the injectors. My car is in winter storage so I'm not sure which side it's on, but it's in the middle. Beauty covers may need to come off to see it too. The newer 2000-2004 intake part number ends in 3572, if I remember correctly. With it on I think that's the easiest way to tell the difference.
Old Nov 15, 2010 | 09:24 PM
trophy hunter
Thank all of you for the responses......
.....crap ! I was affraid of that
To visual differences - ls1 /ls6 C5 intakes
