90mm ls6 intake
Old Nov 14, 2010 | 01:26 AM
notaoldman's Avatar
notaoldman
Default 90mm ls6 intake
hi guys im new here! i got a 2004 z06 with h/c 430/405 with stock intake and t/b.question is does anyone here have any knowlage of this intake mod? or seen any numbers? for 350 bucks just curious if it would help out this car a little.thanks jeff
Old Nov 14, 2010 | 01:49 AM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Are you talking about the TPIS 90mm LS6 manifold??
Old Nov 14, 2010 | 02:09 AM
notaoldman's Avatar
notaoldman
yes
Old Nov 14, 2010 | 07:59 AM
AU N EGL's Avatar
AU N EGL
Good Manifold One of the best.
Old Nov 14, 2010 | 02:26 PM
Bullet Proof's Avatar
Bullet Proof
I saw something on the auction site... a plate that you can use to bolt a ls2 tb to a ls6 intake...it looks like a reducer....idk it this would help or hurt performance?
Old Nov 14, 2010 | 02:38 PM
notaoldman's Avatar
notaoldman
yea i think ill give it a try,for 350 bucks and a t/b it can't hurt right? do these 90mm t/b conversions hurt drivibility at all if properly tuned ,i know it needs a harness to fit the ls2 style but thats all i know...jeff
Old Nov 14, 2010 | 10:32 PM
Mike94ZLT1's Avatar
Mike94ZLT1
That COMPLETELY defeats the purpose of going to a larger TB.
I have one of these intakes and I love it. You will need a tune, but my driveability is perfect.
Old Nov 15, 2010 | 07:27 AM
AU N EGL's Avatar
AU N EGL
As you go from a LARGE pipe to a medium size to a small size pipe or air intake, the velocity or speed of the air increases and flows into the cylinders quicker.
Old Nov 15, 2010 | 09:41 AM
Bullet Proof
so you are saying that going to a 90mm tb to a 78mm opening would increase the flow into the cylinders quicker?
Old Nov 15, 2010 | 11:26 AM
corvettebob1's Avatar
corvettebob1
Not so sure this is true when you have a negative pressure on the small end and atmospheric (14.7) on the large pipe.
If it were true why would NASCAR run restrictor plates to slow down the cars?
What it should do is increase throttle response and decrease top end power, giving the illusion of a faster car.
Old Nov 15, 2010 | 12:53 PM
AU N EGL's Avatar
AU N EGL
It is something worth looking at or into.
Illusion? I would think most ppl would trade increased throttle response and decrees top end power any day.
Old Nov 15, 2010 | 01:37 PM
notaoldman's Avatar
notaoldman
I have one of these intakes and I love it. You will need a tune, but my driveability is perfect.[/QUOTE]
wow finally someone who has one on thier car!!,what are your mods? what hp gain did you see??..jeff
To 90mm ls6 intake
