Cam for a mild build
Old Nov 14, 2010 | 05:07 PM
hermancar's Avatar
hermancar
Default Cam for a mild build
1999 c5 coupe, 39,000 miles,automatic transmission and a2:73 gear.
I am installing new ls6-243 heads,z06 springs,ls6 intake,headers. What is a good cam for low and mid range torque and hp with rpm 6200 max because of rod bolts in this motor. street use. Thanks. PS I am not looking for the most hp but best street and reliability.
Old Nov 14, 2010 | 05:12 PM
slowtealz28's Avatar
slowtealz28
Stock LS6 cam with those springs and no bigger.
Old Nov 14, 2010 | 05:14 PM
zeevette's Avatar
zeevette
Not familiar with your type of setup, but common sense would suggest you need gears, and maybe a higher stall TC before you tear into the motor. I'd do this before a cam, that's for sure.
To Cam for a mild build
