When a corner of my 99 climbs a hump, surb approach,driveway, etc, I get a "POP" sound from that corner.
I think it is coming from the metal end links on my sway bars. It this normal? Or are they too tight or?
Tks.
I wouldn't think them being too tight would make them pop. I would think maybe too loose. Or a loose ball joint perhaps. Or something else loose on that corner (tie rod? bushing? shock?)
Dope
I've checked everything for looseness. It happens at all four corners independently. That's why I'm puzzled.
Do you have the stock plastic endlinks or have you upgraded to the later metal ones?
Interesting that it's all 4 corners, not sure what to tell you there. Usually when I get popping from the corner of a car it's something worn out. I've heard of popping from the rear axles if they aren't lubed in the splines of the wheel bearing/hub, but that wouldn't explain the front.
