I have to get my 97 smogged this weekend. It is all stock except a twin cone air cleaner. Will I have any problems getting it smogged? I live in Ca. Thanks......
You'll be fine. I live in Southern California myself. I had an SLP air box on my F body and have K&N cold air intake on the Vette and all good. Passes smog inspection. As long as your IAT sensor is in place thats all you need. Not like the old days when you had to use your stock air cleaner with heat riser ducts and all that. Computer controlled cars take care of everything.
You are just as likely to be toast when the smog guy sees an aftermarket intake with no C.A.R.B. sticker/plate. I've been told more than once that in order to not put the smog shop at risk of heftly fines, make sure that ANYTHING related to emissions controls is OEM. Even a catch can is illegal, since it is connected to the PCV line.
Just do what I do - swap out the intake for the OEM one, 2 weeks prior to the test. You should give your engine some time to adjust to the lower flow rate.
Taken Care of. I just put the stock one back on. I dont drive the thing that much anyway. Just want to get it passed and not have to worry about it.
Smart move....... I use this time every 2 years to give my aftermarket Haltech CAI a good cleaning and re-oil the filter. It barely takes 30 minutes to change out the air filter to the stock one.
First time I brought my car to my smog shop the owners said no way before I even opened the hood but once they called in CARB # for blower to state and got a verification it was for my year and make it passed just fine. They said it blew cleaner than stock as well. Their shop is very strict and wont pass a car unless its perfect visual wise. They couldn't believe that much HP and passes smog. Gotta love these cars and smog legal!
One of the owners wanted a ride and since the freeway was a couple blocks away....He had to change his shorts when we got back and probably was smiling for a week..
[QUOTE=Dave68;1575966744]You are just as likely to be toast when the smog guy sees an aftermarket intake with no C.A.R.B. sticker/plate. I've been told more than once that in order to not put the smog shop at risk of heftly fines, make sure that ANYTHING related to emissions controls is OEM. Even a catch can is illegal, since it is connected to the PCV line.
I used to own and operate a smog check station here in California. Changing the intake and air cleaner is 50 state legal as long as the IAT sensor is in place. And it makes sense. How could a cold air intake effect emissions? And if a smog check station tells you different I would report them!
I went thru tthis last year.. and NOBODY in the state or at the testing station had a direct answer for me.
I had a Vararam sysyem installed .. a bit more than just a CAI but all the stock connections are in place and are functioning.. I failed the visual..
The guy doing the test said it was'nt OEM so he failed it. I told him the thh rules states that als long as the replecement part has the same function and connections as the replacement part it was legal... thats from the testing rule book!
The state folks that administer the testing folks said it was leagal.
The state refree said "I dont know, Im not sure".... really that what he said! He didnt want to take a stand I told him you guy in the field if you dont know who does...
Best I could determine it was up to teh GODS.. if youy got lucky you'd pass if not... well have a stock system avaliable
It passed with no problems. Lower emissions than my 2000 toyota tacoma 4 banger..... Better gas milage half the time to. Now if lasts 300,000 with know problems Ill really be happy......
I have a Vararam on my car, and passed smog just today, without any issues at all. I put the stock air duct back in place of the Power Duct and removed the Vararam decals. I doubt the typical smog inspection person could even tell that the Vararam is not a stock piece, especially if the red coupler is replaced with a black one. The snorkel type air intakes like the Blackwing might be another matter because of their high visual appearance.
I have spoken to a BAR (bureau of automotive repair) a few times about this and in no uncertain terms, I was told that any aftermarket "emissions-related" part or assembly MUST HAVE A C.A.R.B. sticker - no exceptions.
A Vararam is illegal in CA. If the smog tech knows his or her stuff, he or she will fail a vehicle that has one installed. This is also true of LT headers.
One guy I know thought that a vacuum/boost gauge would be illegal. But this is not changing the operating parameters or emissions of the engine; it is simply measuring conditions. An aftermarket intake could very well cause the engine to run leaner than it would from the factory. Many Z06 owners would get lean codes after installing an aftermarket intake. This is why the manufacturer must prove that the ECU can compensate for the extra air flow before the intake system is granted a C.A.R.B. number.
The trouble with using appearance as measure of pass/fail is that the techs can't possibly know all of the vehicles and what is stock and what isn't. There are far too many vehicles and engines for them to possibly know them all. For many years I had a 1972 Corvette with an LT1 engine. From the factory, it came with a unpainted aluminum high rise manifold, chrome valve covers, and a chrome, open element air cleaner. Every time I took the car to be smogged, I got into a hassle with them because they would see the manifold, valve covers and air cleaner and, say it wasn't stock. The car would always easily pass the actual smog test. Ultimately, after much discussion, they would finally pass the car. I really hated taking that car to be smog checked.
Phil
Thas exactly what Im going to do.. I have two "Collectors" on ewith the VR decal the other w/o....
Exactly...just remove ALL stickers and make it look as stock as possible. The vararam as others have said will not be an issue unless the particular tech that is smogging your ride knows what to look for.
The vararam looks pretty stock if you leave the stickers off.
It really is a luck of the draw thing unless your buddy is the one doing the smog.
