High Engine Rev
Old Nov 21, 2010 | 04:20 PM
captamerica's Avatar
captamerica
Cruising
Default High Engine Rev
Engine revs 3000 to 4000 RPM's when brakes are hit hard. On a 6 speed 2003.
Has this happened to anyone else?
Old Nov 21, 2010 | 08:34 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check EVERY vacuum line for damage. Especially the PCV vacuum lines. Pull them out and make sure that there nit rotting.
BC
Old Nov 22, 2010 | 06:55 AM
99 vett babycar's Avatar
99 vett babycar
how does the engine idle?? steady or surging??
Old Nov 22, 2010 | 07:01 PM
coanan's Avatar
coanan
Bad brake vacuum booster?? Listen for a change in sound around booster when brake is applied.
To High Engine Rev
