Pinging under hard acceleration.
Old Nov 21, 2010 | 07:30 PM
Relsek's Avatar
Relsek
Default Pinging under hard acceleration.
After buying my 1998 vette a few months ago from Craig's List, I was impressed but noticed that when accelerating hard the engine would ping. It happened typically above 3000 rpms with the pedal to the floor. I searched the forum for clues as to what the problem could be. I tried sea foam after reading about carbon buildup on higher mileage cars, that didn't change anything. I began to think it was due to the intake and exhaust mods alowing more air into the mix so I thought I needed a tune to make the fuel mixture match the air. After finding out it would cost me $400.00 to tune it, I thought I would try a few other things first. The first thing I tried was checking the plugs. I pulled a plug out and found that it had NGK tr5 v-power plugs. I decided to try replacing them with stock AC Delcos. Woo Hoo that was it. I couldn't believe the difference, It runs like a scalded dog. I guess the previous owner decided to upgrade to crappy plugs.
My advice is, "if it isn't broke, don't fix it."
Kevin
Old Nov 21, 2010 | 07:41 PM
CARRJET's Avatar
CARRJET
wow, I always thought low octane fuel caused pinging...glad you fixed it
Old Nov 21, 2010 | 08:18 PM
jrose7004's Avatar
jrose7004
I would have figured low octane too.
Old Nov 21, 2010 | 08:24 PM
Relsek's Avatar
Relsek
I have always used 93, my mechanic friend that is a mechanic for a GM dealership suggested I use the stock plugs, he's run into this before.
Old Nov 21, 2010 | 09:19 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Seems odd, glad you fixed it though. I would have figured bad gas, carbon or leaner due to an intake.
Maybe they were gapped wrong or jacked up (old). NGK are great plugs to use in these motors. Not considered a downgrade, but don't last as long since they are copper plugs. Most of the high HP guys run them. Been running NGK TR55 or TR6 (one step colder) for 6 years with zero issues.
Old Nov 21, 2010 | 09:30 PM
Relsek's Avatar
Relsek
Maybe that was it then, just worn out.
Old Nov 21, 2010 | 09:37 PM
motogib1's Avatar
motogib1
Just as a data point, did you check the gap on the NGK plugs and compare to spec?
Old Nov 22, 2010 | 06:45 AM
99 vett babycar's Avatar
99 vett babycar
I'll bet they were way off
Old Nov 22, 2010 | 06:56 AM
Relsek's Avatar
Relsek
I just went out to the garage and checked them, they are .045
To Pinging under hard acceleration.
