Rocker arm recommendations
Old Nov 25, 2010 | 04:22 PM
jobberone's Avatar
jobberone
jobberone
Default Rocker arm recommendations
I'm replacing my heads on my 347 TT setup. Going to AFR 230s which I can't find out much on. First has anyone any experience with the AFR 230 heads? Second I need to know what rocker arm to use. I can get a better price on Jesel rockers but I've heard they weren't best for my app. My only other alternatives IMO are the Comp cam 1500 or the same T&D rockers. Something about shims and the Jesel rockers with the AFR. Some techs: lift 620s. rev limit 7000. shift point 6800. Springs I don't know height yet as they are supposedly going to be custom springs. Probably 1.74 or so. Seat pressures in the 180 range intake with opening pressure about 540. Boost limit 20-22. Rockers 1.7 ratio. Normal hyd cam bearings. Caddy lifters.
Old Nov 26, 2010 | 08:02 AM
vettenuts's Avatar
vettenuts
I have modified 205's and went with the Yella Terra rockers. For any of the rockers mentioned, you need to ensure the wipe is narrow and centered on the valve stem before measuring for the pushrod length. With the YT's, I got the wipe down to 0.045" width of wipe pattern.
Old Nov 26, 2010 | 09:05 AM
Jim in Mich's Avatar
Jim in Mich
I too went with Yella Terra's. I think they are the best bang for the buck. Just got my set Wednesday just waiting for a warmer day to put them on. I helped put a set of 1:8 on a C6 without a cam and they quieted the valve train noise quite a bit. I have a Lingenfelter with a high lift cam and it sure is noisey, hope to quiet it down with the shaft mount YT's. Although the stock rockers are tough they do have a lot of slop and make noise.
Old Nov 26, 2010 | 05:35 PM
vsocks1's Avatar
vsocks1
I am happy with the Jesel Sportsman Series I installed in mine!
To Rocker arm recommendations
