LS2 404ci build
Old Nov 25, 2010 | 04:37 PM
baezi z06's Avatar
baezi z06
Default LS2 404ci build
Hi guys
I just wanted to make a new thread about my first home build
here is my Vette
C5 2003 50th anniversary convertible whith complete Z06 suspension and drivetrain and MN6 gearbox
LS2 402ci NA
best 1/4mile time so far is 11.16@126 but that was whith bad top pistons rings on 4 pistons, had a lot of blowby was 20% less compression on them 4 cylinders then on the others.....
The reason for that is last spring i had a bad knock so bad it broke one of my piston and made a deep crack in one.
It also looks like in two other pistons a small piece from the broken piston had hammered them a lot.
but for some reason i can´t understand i juste swapped out that 4, but that was a mistake because the rings was crushed/hammered on them all
And then after few months of driving and some drag racing with alot of blowby i spun a bearing!!
so the engine had to come out
but what i saw was this: a crack in my Crank, seems like a little piece broke out of the small crack and then offcourse the bearing was gone that my guess !!
And i saw the piston where all scratched too and the sleaves had bad marks in them.....
My motor was trashed.....
All the top rings on the 4 pistons that had not been swapped out was like this
So i went whith the block to my local machine shop
they did a .005" clean up on the sleaves (didn´t wante to take more off)
And ordered from Jon@TSP New pistons (.005" bigger) Wiseco 4.010" -10cc, and i needed two new rods they where damadged after the bearings
The Crank i got claimed.
TSP helped me out there, but i needed new ballance for it offcourse, so TSP arranged that for me too.
and then i bought all new bearing and gaskets!!!
So it´s time for building me a 404ci
LS2 block after clean up
Pre assembly, check bearing clerance
Had one here build me a Tourq-plate
gaped the rings for NOS
Final clean up for the final assembly
NEW Eagle 4340 steel crank 4.00" stroke install
New TSP Wiseco 4.010" -10cc dish pistons + Eagle H-beam rods 6.125"
Wiseco GFX steel top ring 2nd napier
Shortblock´s asembly finished LS2 404ci
CAM install TSP TX-Giant 248/254 . 615" 622" 114LSA (110ICT)
blocks covers on and LS7 lifters and liftertrays....
oil pan
ARP head studs
Doubled checked the PVC
Bolt on the Trick Flow 215cc heads 59cc opened up to 4" for bigger bore and the Harland sharp rockers 1.7
FAST 92mm ported intake LS2 90mm TB ported (gt500 bosch 53lbs injectors)
LS2 404ci Longblock Ready=D>
so no i need to find time to throw it into the car v
Baezi
Old Nov 25, 2010 | 05:24 PM
jobberone's Avatar
jobberone
jobberone
Nice. Good job. Keep us up to date.
Old Nov 25, 2010 | 10:48 PM
vsocks1's Avatar
vsocks1
Hope all goes well from here!
Old Nov 26, 2010 | 12:35 AM
memphis_vette's Avatar
memphis_vette
nice work...keep us up to date
Old Nov 26, 2010 | 07:30 PM
sloride's Avatar
sloride
that sounds nice one day I will put one in
Old Nov 26, 2010 | 08:38 PM
rkboz's Avatar
rkboz
I almost hyperventilated....very cool.
Old Nov 26, 2010 | 11:13 PM
Dale002's Avatar
Dale002
I love engine builds. The pictures give me a stiff feeling.
Good luck with the built.
What crank did you use?
How much hp are you guessing?
I'm looking for a cheap engine myself to transform to a 427.
Old Nov 27, 2010 | 09:52 AM
baezi z06's Avatar
baezi z06
thanks for all good comments
i got New EAGLE 4" crank
this is a 520-530RWHP@6000 and 490-500TQ@4700 setup
The heads i´m running TFS 215cc are now the bottle neck i would think :o
there is more in it if i would upgrade them to for example TFS 235cc
Exhaust i´m running is kooks 1"7/8 and dual 3" and dual cutouts and TI catback
post in the install of the engine into the car and maby first startup
baezi
Old Nov 27, 2010 | 08:33 PM
coanan's Avatar
coanan
Could you share the cost?
Old Nov 28, 2010 | 04:52 AM
baezi z06's Avatar
baezi z06
Are you talking about rebuild cost or?
If so, it was round $ 1300 for parts i ordered from +shipping + Machine shop here in Iceland
New pistons and rings: around $790
2X new Eagle H-beam Rods: $160
Eagle Crank : $0 (got it claimed)
rotating ballance in USA : $225
gaskets and bearings
Machine work here in Iceland was $550 (was expensive)
(boring/honing/cleanup)
So this is around $2200 in cost whith shipping (shipping is expensive to Iceland)
And i do "all" other work my self
In 2009 i bought the TSP LS2 402 shortblock + camshaft for well over $6000, but i sold the old 346ci shortblock for around $3000
Baezi
Old Nov 28, 2010 | 11:25 AM
JJ 86's Avatar
JJ 86
Old Nov 28, 2010 | 01:35 PM
Corvette Don's Avatar
Corvette Don
To LS2 404ci build
