Heads, cam HELP
Old Apr 5, 2002 | 09:33 PM
Andy_A's Avatar
Andy_A
Default Heads, cam HELP
Just received my Katech Stage II heads and cam UPS yesterday. On Monday the balance of my order should be here to include: LS6 manifold, underdrive pulley, Belanger long tube headers and Cloyes adjustable gear set and C5R timing chain. The PCM to be programmed with my Katech modified Superchips Microtuner.
Cam specs: 566 Intake
569 Exhaust
220 @50 Intake
226 @50 Exhaust
@114 lobe
Question: Should we set the Cloyes adjustable gear set to 2 degrees or zero? Comments would be
appreciated.
Old Apr 5, 2002 | 09:57 PM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Default Re: Heads, cam HELP (Andy_A)
to be exact you really should degree the cam. I usually put them in 2 degrees advanced just to make up for the inevitable chain stretch. I know some of the builders will disagree with this but every one I pull apart has at least that much chain stretch in a short time. I have the Hex-Adjust in mine. It' sreal easy to set.
Old Apr 6, 2002 | 02:28 AM
NYtoCA's Avatar
NYtoCA
Andy,
How much did the stage II H/C package cost you? What kind of gains are you expecting from them?
Thanks,
Frank
Old Apr 6, 2002 | 03:52 AM
Austrian Vette's Avatar
Austrian Vette
I have the "NON STRETCH" cloyes heavy duty timimng chain.
I have set the adjustable timing gear to "0".
Works good.
Michael
To Heads, cam HELP
