Squeaky NEW Brakes
Old Nov 28, 2010 | 09:44 PM
CLEAR's Avatar
CLEAR
Default Squeaky NEW Brakes
I put a full set of Brakeperformance.com slotted and dimple drilled rotors on. I used the brake pads that came with them and they squeak alot. I used grease generously. Should I get different pads or what can I do?
Old Nov 28, 2010 | 09:50 PM
98c5lswon's Avatar
98c5lswon
"I used grease generously" - could be the problem, maybe some grease got onto the pads/braking surface on the rotor
It could also just be the brake in coating that come on many aftermarket brakes
Have you heat cycled them properly?
Old Nov 28, 2010 | 09:57 PM
Will at RSI's Avatar
0Will at RSI
Former Vendor
It could just be the brake pad. Check out the Brake section of our Black Friday sale and grab a set of Hawk HPS pads.
http://www.racingsolutions.com/merch...g/blackfriday/
Old Nov 28, 2010 | 10:15 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
The pads are fine. I sold as set to a guy and he said they were just as good as Hawk pads he had.
When you do the bed in the coating from the rotors get on the pads. take the pads off and clean the coating off the pads and you should be good.
Old Nov 29, 2010 | 08:01 AM
runner140*'s Avatar
runner140*
New pads and rotors have a procedure for bedding....is that spelled correctly? That procedure usually comes with new pads....At least
Hawk pads come with specific instructions. (ie. brake hard from 60 mph ....then brake hard from 40 then at 20mph)
Old Nov 29, 2010 | 09:39 PM
CLEAR's Avatar
CLEAR
I got no instructions. I have been trying to go easy on them. How do I clean them???
Old Nov 29, 2010 | 10:23 PM
Jnape's Avatar
Jnape
http://www.tirerack.com/brakes/tech/....jsp?techid=85
This covers a variety of processes. Pick the one that fits and do it. I doubt that you have any pad transfer to the rotor in any quantity to warrant you manually remove it. It is the same pad that the rotor started with so no dissimilar compounds to worry about......
Old Nov 29, 2010 | 10:26 PM
0331MARINE's Avatar
0331MARINE
They should have come with them.
http://brakeperformance.com/installa...structions.php
Old May 12, 2011 | 02:21 PM
CLEAR's Avatar
CLEAR
Still squeaking about drive me crazy. Thinking about just buying some new wagner thermoquiets. How do i tell for sure if its the front or rear making all the noise? The old stock pads squeaked but these new ones are worse.
Old May 12, 2011 | 04:22 PM
Bluefire's Avatar
Bluefire
This is true. However, a main point to note in the bedding process when stopping from 40 mph and 20 mph is do not completely come to a stop.
Old May 18, 2011 | 07:26 PM
CLEAR's Avatar
CLEAR
I did take the pads off today and they were glazed. I sanded them down and reinstalled. still squeaky but better. I noticed that the shims werent on very tight.
Old May 30, 2022 | 03:13 AM
mollyenholm's Avatar
mollyenholm
5th Gear
It is quite common for new rotors or brake pads to squeak within the first few days before they're completely broken in. If it has been more than a few days and the squeaking still hasn't stopped, you should have your brakes looked at by a professional.
To Squeaky NEW Brakes
