Radio keeps playing
Old Nov 29, 2010 | 12:56 PM
larry.avery's Avatar
larry.avery
Cruising
Default Radio keeps playing
Even after I open the door and get out of the car the radio keep playing, sometimes for several min. I can open the passenger side door and it stop's.
Old Nov 29, 2010 | 01:20 PM
oh1vette's Avatar
oh1vette
Sounds like you have a window valet installed....
Check your OBD 2 port under the dash...
It'll look like this:
http://www.westcoastcorvette.com/p-3...-04-c5z06.aspx
Old Nov 29, 2010 | 01:32 PM
byronhunter's Avatar
byronhunter
I've outlined in red the circuit you should check. Either Ajar Switch, Wiring or Connectors.
Old Nov 29, 2010 | 01:55 PM
_zebra's Avatar
_zebra
or it sounds like the same problem i had. does the 'security' light flash, the interior lights come on, or door chime work? if none of these, it sounds like the sensor ain't working. i took my door panel off & saw that some idiot unplugged it before i bought the car.
Old Nov 29, 2010 | 02:18 PM
larry.avery
Cruising
What does this sensor look like? I
ve had the door panel off and only saw the one big plug in for the windoes and stuff.
Old Nov 29, 2010 | 03:33 PM
Fast Cop's Avatar
Fast Cop
Did you name your car Christine?
Old Nov 29, 2010 | 03:54 PM
_zebra's Avatar
_zebra
look down the window channel by the latch. there should be three connectors plugged in. the 'door ajar' plug, if i remember right, is the one on top & closest to the interior side
Old Nov 29, 2010 | 04:22 PM
larry.avery
Cruising
Oh yeah, I remember seeing those plugs and they were all pluged in. There is a rod that attaches to the latch that slides a black plastic thing with prong's on each end. What is that for?
Old Nov 29, 2010 | 05:02 PM
_zebra's Avatar
_zebra
sounds like part of the locking assembly, but i could be wrong
Old Nov 29, 2010 | 05:34 PM
Chris Stewart's Avatar
Chris Stewart
My Cavalier does that too. The computer will save your battery and turn off the radio after 20 mins, but it still isn't right. I'm thinking its the door switch.
To Radio keeps playing
