Shift know in a 2002 A4
Old Apr 6, 2002 | 08:55 AM
Straightpipes 1HD's Avatar
Straightpipes 1HD
Default Shift know in a 2002 A4
Before I start, anyone know how to change the shift **** on the A4? I remember seeing a link to that one somewhere here before, but can't find it now.
Old Apr 6, 2002 | 09:02 AM
Sam Lin's Avatar
Sam Lin
Default Re: Shift know in a 2002 A4 (Straightpipes 1HD)
There's a spring clip on the bottom of the front end that holds the **** down, you need to pry it forward and off, then the know should pull up and off. At least that's what I remember from somewhere else, I haven't done it myself.
Sam
Old Apr 6, 2002 | 10:43 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Shift know in a 2002 A4 (Sam Lin)
use an eyeglass flathead screwdriver to pry out the "staple" holding the **** onto the shaft....lift off :)
to use any of the M6 *****, you'll need an adaptor :cheers:
Old Apr 7, 2002 | 12:46 PM
laramr's Avatar
laramr
Active Streak: 90 Days
Default Re: Shift know in a 2002 A4 (Mean Green 2000)
Apply the E-brake and put the car in neutral to give yourself more room to work. It takes some effort but the small c-clip on the forward side of the **** will come out.
To Shift know in a 2002 A4
