241 head vs 243?
Old Dec 3, 2010 | 07:47 PM
z06 hellcat's Avatar
z06 hellcat
Default 241 head vs 243?
whats the difference between the two im looking for a pair of heads to put on a lq4 6.0
Old Dec 3, 2010 | 10:24 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Better flow with the 243's. Dont put 241's on it.
Old Dec 4, 2010 | 01:48 AM
manley845's Avatar
manley845
If you have the option then do the 243's. More compression and they don't have the airflow issue that the 241's have at higher valve lift. But if you do choose 241's just have a shop blend the short-side radius if not anything else. I think Patriot sells a reasonable priced set of heads or if you have the bones for it go with AFR heads
Right or wrong, here's where I got some of the info.
"The major change in the LS6 intake port was alteration of its "short turn" or "short side" radius, the area of the port just upstream of the valve where the port floor curves down to the valve seat. The LS1 port suffered an air flow stall at high valve lift, induced by the short-turn radius and the goal was to eliminate that."
http://www.idavette.net/hib/ls6/page4.htm
Old Dec 4, 2010 | 08:54 AM
AU N EGL's Avatar
AU N EGL
243s.
If you are doing a valve lift over .570 get the light wt valves and appropriate beehive springs. Double springs are overkill and can hurt more then help
To 241 head vs 243?
