Shifter Knob loose
Old Dec 6, 2010 | 12:40 PM
wander07's Avatar
wander07
Default Shifter **** loose
My shifter **** seems to be coming loose on my 2002 C5 automatic. I can't seem to see any kind of set screw or locking screw of some sort. Any ideas on how to tighten up?
Old Dec 6, 2010 | 12:52 PM
hotwheels57's Avatar
hotwheels57
If I'm not mistaken, it's attached with a "staple" located on the front leading edge. It may have vibrated loose...
Old Dec 6, 2010 | 01:01 PM
wander07's Avatar
wander07
the front leading edge of what?
Old Dec 6, 2010 | 01:34 PM
hotwheels57
Of the **** itself.
For future reference and specifically in this case: In C5 Tech, use search or search this forum (in the red banner) with keywords "removal of automatic transmission ****". Nothing much gets deleted from the archives. This manner will find past threads/replies to almost any question you might have about your C5.
You should find this...
http://forums.corvetteforum.com/c5-t...***-loose.html
Old Dec 6, 2010 | 01:39 PM
wander07's Avatar
wander07
Old Dec 7, 2010 | 03:21 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you pry up the shift pattern plate on the top of the ****, you will see an aluminum key pressed into the **** between the **** and the shift lever. That key is refered to as the DEMOND KEY. Pull the key out, screw the **** down all the way "TIGHT and in the correct orientation) and reinsert the key. Drive it in between the **** and the shift lever. That key keeps it from rotating and loosening.
BC
Old Dec 7, 2010 | 03:38 PM
hotwheels57
He has an automatic transmission...
memphis_vette's Avatar
memphis_vette
BC
he is talking about an auto tranny i believe...there is only a staple like clip on the very front of the shifter...bend the clip out then re-insert...fixed my loose shift ****
Old Dec 7, 2010 | 03:47 PM
wander07's Avatar
wander07
Good idea, thanks Bill
Old Dec 7, 2010 | 06:54 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yea,, it helps to actually READ the post!
Sorry, i dont have any auto info for ya.
BC
Old Dec 15, 2010 | 12:22 PM
wander07's Avatar
wander07
Went to remove clip, but there is no clip to be seen, probably broke off inside ****. Cant get **** off. Any other suggestions?
Old Dec 16, 2010 | 01:17 PM
Try using a very small screwdriver and see if you can catch some of the staple that is holding the **** on. If not, not sure how you will get the shift **** off.
To Shifter Knob loose
