2003 how do you adjust low idle speed
2) Open the engine compartment fuse box cover and remove the two 10 amp fuses from position numbers 16 & 23.
a) According to the manual there are two fuse boxes. Use the engine compartment fuse block for this procedure not the instrument panel fuse block.
b) Engine Compartment Fuse Block (correct one): 16 is Powertrain Control Module A and 23 is Powertrain Control Module B.
c) Instrument panel fuse block (wrong one): 16 is Air Bag, 22 is Body Control Module-Ignition and 23 is Body Control Module-Ignition 2.
NOTE: Your DIC will now display “check” messages for ABS, etc… Do not worry as this is normal.
3) Turn the ignition key to the “OFF” position.
4) Return to the engine compartment fuse box and re-insert both 10 amp fuses for positions 16 & 23.
5a) Idle relearn for an M6:
1) Start the engine and allow the coolant temp to reach a minimum of 176 degrees F. Allow the engine to run at this minimum temperature for at least 5 minutes.
2) After the 176 degree, 5 minute minimum run, shut down the engine for a minimum of 30 seconds.
3) Restart the engine and check for DIC error codes (there should be none).
5b) Idle relearn for an A4: (different)
2) Allow the car to idle in DRIVE, with air ON and then OFF, for 5 minutes each, and then in NEUTRAL, with air ON and then OFF, for 5 minutes each.
3) Turn the car off for at least 30 seconds.
4) Restart the engine and check for DIC error codes (there should be none).
6) Drive car for a minimum of 30 miles at varying rpm settings and speeds. PCM will now re-learn and adjust for the new air flow and temperature at the intake.
a) If error codes persist, repeat steps 1-7. Make sure fuses are properly inserted before repeating steps.
b) Do not deviate from the sequence outlined above. If you do, restart the sequence from scratch.
c) Steps 1-4 are also necessary if you ever disconnect your battery or lose power for any reason.
A manual trans should idle at 725 all the time
IF you have recently dis connected the battery--or the battery got real low or have had the ECM re-flashed---The fuel trims will be re-set to "0" and have to learn out all over again during that time it may idle wierd or even surge/die---usually after 50-75 miles of normal driving it should learn-out
An eng with a aftermarket cam requires the idle to be higher----
