spark plugs
Old Dec 9, 2010 | 06:01 PM
renec4vette's Avatar
renec4vette
Default spark plugs
i am fixing to change my 99 c5 sparkplugs, anyone know which ones are the best and to what gap should they be calibrated? thanks guys!
Old Dec 9, 2010 | 06:26 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You can't go wrong with stock plugs and I believe the current plug is 41-110. They are factory gapped and should not be altered. There's a lot of thoughts on lots of plugs out there and everyone has an opinion. Some better, some worse...its your car, do as you wish but at least know the stock plugs were designed to work with a stock engine. I'm sure there are better ones too depending on the requirements. If you are still running stock wires, time to change them too. Gene Culley has a good price on GM Performance Wires right now...www.gmpartshouse.com or see his monthly postings of parts in here.
Old Dec 9, 2010 | 06:43 PM
renec4vette
thank you very much, will do!
Old Dec 9, 2010 | 06:51 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
For everyday use, you can NOT beat the stock iridium plug. The GM Performance red wired are more than adequate for any C5 or C6.
You will NOT gain any performance or power from any of the aftermarket wires or plugs over stock. PERIOD.
BC
Old Dec 9, 2010 | 07:03 PM
renec4vette
thanks bill!
Old Dec 9, 2010 | 08:08 PM
lucky131969's Avatar
lucky131969
BC
....except for MSD's..................
Old Dec 9, 2010 | 09:08 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Oh,,,, boy,,,
Yea,, there are other wires ,,, but,,, like I stated. Your,, NOT,, going to gain any performance or efficiency gains form wire A or wire B.
You can see what LUCKY is getting at, Select your personal wire choice and DO NOT go for the performance gain HYPE!!!
The GM Red Performance wires have an EXCELLENT QUALITY Reputation and reliability record. Thats what your looking for in a spark plug wire.
Old Dec 9, 2010 | 10:58 PM
lucky131969
Oh,,,, boy,,,
Sorry Bill, I couldn't resist..........hehehe......
Old Dec 10, 2010 | 12:09 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEA,,,,,,,,,,,,,,,,,,,,,,,, I KNOW,,,,,,,,,,,,,,,,,,,,,,,, Thats why I posted!
Old Dec 10, 2010 | 02:01 AM
manley845's Avatar
manley845
Check the gap anyways. They could have been dropped. Also, the gap is often manufacture set at (i think) .040" and that is not correct for your application. I don't have my manual handy, but I think they need to be .060".
(yup, just checked and delco 41-110 are set at .040")
Not that it'll really make any difference, but a "better" plug would be the more costly platinum or iridium plug with the finer electrode, it think they refer to them as Laser Tip (or something).
I did see several options of plugs, all with different gaps. From .035 - .060"
It won't make a noticable difference in your car, but it is recommended to not adjust the gap more than (crap, it just slipped my mind) but i think it's like +/-.005" from where the manufacturer has it set. It's a geometry thing. Dunno, i always adjusted greater than +/- .005" ..... anyways, wish I could find that reference.
Eh, just dont use Champion =D
Old Dec 10, 2010 | 09:29 AM
jedblanks's Avatar
jedblanks
Don't think you can gap the Iridium plugs. The gap is different than the plat plugs.
Old Dec 10, 2010 | 10:16 AM
manley845's Avatar
manley845
You can set the gap on iridium, platinum, and copper plugs.
What you need to be mindful of is the method used to alter spark plug gap. DO NOT PRY AGAINST THE CENTER ELECTRODE!!!
Those cheap lil round gap gauges have a hole that many people use to attach it to there key ring, well it is actually supposed to be use to move the ground electrode without having to touch the center electrode. DO NOT ADJUST THE GAP BY PLACING THE GAUGE IN BETWEEN THE ELECTRODES AND TWISTING AND PRYING THEM APART!!!!
Gap requirement is different for each engine application also.
If your engine is stock then .060" is good.
tip: leaner mixture = larger gap; richer mixture = smaller gap
To spark plugs
