Coil Overs Question
Old Dec 11, 2010 | 09:59 AM
jeanlucpicard's Avatar
jeanlucpicard
Default Coil Overs Question
I have a 2001 C5 that I track road race and am looking into replacing the VBP front / rear extreme bow springs with a set of coil overs.
I have reviewed Doug Rippie and LG Motorsport versions and wondered at the differences. The cost is not an issue to me.
Questions like: ride height affect, durability and quality are my main concerns. I do not adjust my ride height but do not want to install the coil overs and see my fender wells laying on my tires. I run 18" front and 19" rear on the car.
If anyone experienced with coil overs could spare a few minutes of their time and experience and provide some guidance it would be appreciated.
Old Dec 11, 2010 | 04:59 PM
Rob's 73's Avatar
Rob's 73
Call Anthony at LG. He will give you solid advice even if you don't buy theirs. I ended up getting the LG G2s. Not installed yet. If you want it low he will tell you about their drop spindles. Pricey but you will be able to retain proper suspension geometry. Good luck.
Old Dec 12, 2010 | 06:30 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I have the LG GT2s with an 18/19 setup and Track as often as I can. Here's stock and right after th CO install right out of the box;
Stock
Coilover install
It's settled a tad bit more... I have the shocks roughly mid way so I have alot adjustability up or down.
If you're car is a dedicated track car the G2s would be the weapon of choice I would think. I max my dampening out for the track at 12/11 and run them softer on the street...
Old Dec 12, 2010 | 04:55 PM
FKING1's Avatar
FKING1
Very happy with my PFADTS. On abot 3 yrs on my 2000.
Autocross the car and there are 16 adjustments from soft to hard.
Old Dec 12, 2010 | 07:56 PM
Solofast's Avatar
Solofast
There isn't much if any reason to change to coilovers if you aren't going to be adjusting spring rates frequently. You can get all you need from Z06 or T1 springs if the car isn't a dedicated track car.
What will substantially improve the performance of the car on the track is a good set of shocks, and if you do some reasearch the Penske's are probably the best thing out there. Hardbar has a set of Penske's that you can equip with coilovers or can be used with leaf springs. They aren't cheap, but if you are looking for performance they are probably the best thing out there, even if you were to spend more on some of the higher price setups.
I've see the inside of the Pfadts, and I wasn't impressed. The LG's are based on Bilstein parts so the are basically good shocks too. Don't know enough about the Rippie stuff so I can't comment on them.
If price isn't an object, go with the Penske's, you won't be disappointed.
Google Far North Racing. Dennis Grant has years and years of experience with pro racing teams and knows shocks inside out. Read what he has to say and then make up your mind.
To Coil Overs Question
