Driver window leak
Old Dec 12, 2010 | 10:30 AM
TheeMike's Avatar
TheeMike
Default Driver window leak
My 2002 Coupe has leaked since I got it 3 years ago and I am tired of getting wet.
I have adjusted the window in as far as it will go but it still "sits on" the weatherstripping rather than "in" the weatherstripping. There is no blow-out clip on the drivers side (looks like it was broke off before I got it). Would that help? I know it is a stupid question, but...
If this is what I need, where can I find a blow-out clip?
Thanks,
Mike
Old Dec 13, 2010 | 12:47 PM
Randy_medion's Avatar
Randy_medion
Sorry for my English, I'm from Europe, but I'll try to descripe. I had that same problem. Water is coming from the point where the roof stripping meets the door stripping, turned out to be the roof pin/clamp did not close properly, I just put a piece of paper between that little iron ring, so that it would be tighter when you close it
Old Dec 13, 2010 | 12:52 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
have you read this?
http://forums.corvetteforum.com/c5-t...ak-checks.html
To Driver window leak
