This should prob be posted in the Audio/Electronics forum...
Can you elaborate on "distortion"? Is there any hissing or popping? Does it seem to be concentrated in the bass frequencies, or is it affecting pretty much the entire audible range? Is it more present at low volumes, high volumes, or is it volume-independent? If you have a CD player, is this also affected or is it just the radio?
Probably the head unit but not sure. I'm too having a distortion issue with the FM but just got the discs in the player reset, so will continue identifying if its the head unit or the amplifier.
Thanks for the tip to put in audio/electronics, did not think of that. I will give that a shot.
Best description of distortion is a type of "fuzzy/growly" type feedback.
Sorry, that's not the best description, but I have tried to adjust everything available on the radio, Bass, Treble, Fade, etc.
I keep thinking it might be the speakers, but obviously I'm no an expert.
No problems playing a CD.
Reason: added info.
I replaced my door tweeters with aftermarket. I think I spent maybe $50 and the sound quality is 100 times better than stock. I got the idea from a thread in the audio section. The distortion went away completely.
If your problem were related to the speakers or amplifier then it should affect all audio sources. Sounds to me like it's a problem with the antenna or radio receiver, or something closely related. A loose connection somewhere could result in a fuzzy/growly sound.
If it were speaker/amp related then your CD's would sound distorted too. Sounds like the tuner in your head unit is going and it would probably be easier to just replace the head unit and call it day. You should follow what others have said too and post this in the audio section, maybe theres an easy fix we don't know about. Good luck bro!
