Small filter on oil cap?
Old Dec 15, 2010 | 11:28 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Default Small filter on oil cap?
I've seen a few cars that have what looks like a small air filter where the oil cap would go. I'm curious what this is for.
example is on this car:
http://forums.corvetteforum.com/c5-c...-16-800-a.html
Old Dec 15, 2010 | 11:48 PM
LoneStarFRC's Avatar
LoneStarFRC
Sometimes found on blower cars, it's a crankcase filter that's allows air to enter the crankcase preventing pressure buildup.
It's also usually illegal and will not pass a visual emissions inspection in most states since crankcase fumes are open to atmosphere.
Old Dec 15, 2010 | 11:51 PM
00Corvette's Avatar
00Corvette
Just called a simple 'breather'
Old Dec 16, 2010 | 12:47 AM
TheRadioFlyer
Supporting Vendor
Pros/Cons of this piece? (legality aside)
Old Dec 16, 2010 | 01:24 AM
manley845's Avatar
manley845
Mechanically speaking, all pros. (depending on the type, and frequency of cleaning, and oil film or drip may be noticed on the engine though. Keep it clean is all)
Legality speaking - It violates federal emissions law. So, depending on how hard it is to re-install the oil cap before a test, you may not want to try to controversial 'mod'
Personally, I do not trust the effectiveness of the PCV system to properly vent the crankcase so I installed a $10 Mr.Gasket one from Autozone. I clean it every so often and all is well. No more dipstick popping up, and I've noticed less oil consumption between oil changes.
Here's a couple pics:
Old Dec 16, 2010 | 01:47 AM
Last C5's Avatar
Last C5
Another route to go is to run the valve cover line over to a catch can with a breather on it like a Canton Racing Products 23-032PC and you get the best of both worlds. Positive ventilation and no drips on the engine. You're not smog legal, but I'm not telling.
Old Dec 16, 2010 | 01:56 AM
LoneStarFRC
Since no two engines are identical, each one may have a bit more or less blow-by, which is a function of ring seal plus the amount of boost chosen which will in turn affect any vapor/oiliness issues at the breather cap. Bit of dirt magnet so ongoing attention to cleaning like manley845 said.
The other possible con I've heard is hood clearance, depending on the choice of hood and the particular breather chosen, etc. Seems that one would be fairly easy to solve though.
Give Andy at A&A a call or maybe Chris at ECS as these guys are a couple of the blower gurus on the boards and have probably seen it all at one time or another regarding blower cars.
How you liking your new huffer George?
Old Dec 16, 2010 | 10:28 AM
TheRadioFlyer
Supporting Vendor
I had an EE catch can before the blower was installed, but it had to be removed for clearance issues.
I'm pretty sure my 140K mile 97 LS1 has plenty of blow by as it has some pretty heavy white smoke when we ran it on the dyno after the blower install. I"ll post over on the Fi board to see what they think.
Old Dec 16, 2010 | 11:00 AM
Higgs Boson's Avatar
Higgs Boson
get a vacuum pump.
Old Dec 16, 2010 | 11:13 AM
manley845's Avatar
manley845
Originally Posted by Higgs Boson
get a vacuum pump.
Old Dec 16, 2010 | 11:18 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Here is a link to our breather caps, one of the main differences between ours and one of the cheapies is that we have an oil seperator in the cap and the filter. It keeps the cap from dripping oil, even on cars with a lot of blow by.
http://www.eastcoastsupercharging.co..._breather.html
Old Dec 16, 2010 | 11:20 AM
lucky131969's Avatar
lucky131969
get a vacuum pump.
Complete overkill.......
Old Dec 16, 2010 | 11:33 AM
manley845's Avatar
manley845
But hey, so is an 800hp engine, but we all would love one
D&A'sDad's Avatar
D&A'sDad
What did you have to do to make fit the oil fill cap? Or does it come ready to screw in?
Old Dec 16, 2010 | 11:42 AM
lucky131969
Post #11
Old Dec 16, 2010 | 11:56 AM
manley845's Avatar
manley845
It is a push-in style breather that comes with a new valve cover grommet for an older V8 engine. It just happens that with the grommet inplace on the breather, it fits securely in the oil filler tube. It's not threaded in place, but the top of the breather just barely touches the hood liner and adds in its retention.
I have had it in for more than 15k hard miles over the last several months and have had no oil drips or issues with it staying in place. I have only cleaned it twice, but only because I was changing the oil, not because it needed it.
This is not something I would suggest to a person that needs to have a "set it and forget it" mod. Only because I could see someone else being uncomfortable with the method of install.
I did look at the link in post #11 and that would be a nice item to install and not worry about. For me though, it looks a lil ghetto having a hole drilled in the top of a oil cap and shoving in a breather. Not to say that mine is done right, but other than removing it or me telling how it is installed, it looks like it belongs there.
Old Dec 16, 2010 | 12:17 PM
lucky131969
While I do think you have a tasteful and cleaning looking engine compartment, there isn't anything about that breather...that looks like "it belongs" there.......and if your sig is accurate concerning your mods, it is not even necessary.
To Small filter on oil cap?
Old Dec 16, 2010 | 12:35 PM
manley845's Avatar
manley845
Awwww, did you take my comments personally???? It's gonna be okay.
Eh, neither came from the factory, so neither "belong" there.
But I do prefer the looks of my cheapie one. I did almost make one like the one offered in the link in post #11, but I just don't like that look.
I have seen a very nice looking thread-in model for GM engines, but it looks similar to mine once installed and costs about $70. I don't mind spending money, but I don't wanna pay more money for the same darn thing. Case in point, that breather offered in post #11 can be made for less than $10 if you use you old oil cap, so why pay $60 for someone elses?
As far as being necessary, no car NEEDS to have crankcase pressure vented. The engine will find it's own means to vent, just as they did decades ago. However, giving an engine an ample means to vent or better yet installing a source of vaccuum is simply going to reduce blow-by and seal leaks. For me, a $10 breather is worth the added breathing capablilities, should the engine require it. If the engine does not require the added breathing, then I have not lost anything. And frankly, if someone is worried about $10 or even $100 bucks then they might need a better job.
Old Dec 16, 2010 | 12:58 PM
bgreen83's Avatar
bgreen83
Doesn't this also replace he vent tube when oh switch to an ls2 throttle body?
Old Dec 16, 2010 | 01:44 PM
lucky131969
Ah, no......because my setup works, and more importantly, it's actually needed, not just for show...
Really? And without a means to vent, where does said pressure go ? Out the oil seals? Perhaps you are too young to remember GM engines with vented oil caps on the valve covers....."decades ago"....
