Small filter on oil cap?
Old Dec 16, 2010 | 02:48 PM
D&A'sDad's Avatar
D&A'sDad
thanks manley845
Old Dec 16, 2010 | 03:11 PM
manley845's Avatar
manley845
Originally Posted by lucky131969
Ah, no......because my setup works, and more importantly, it's actually needed, not just for show...
Please show the empirical data the backs your claim. You, like most, do what they "think" is needed, but really have no verification for your actions. I am sure you have no idea what the demands of your engine are, and what is specifically required to satisfy those needs. That being said, your ventilation system is probably performing just fine, but I also don't believe that you planned it based on needs. The ventilation system on your engine would probably handle increased needs, yes? Well, if that's the case, then you too have a system that is just for show. But who cares, having a higher capablility is better than not enough, right? So, the conclusion I have come to, is that having a breather on my engine is not wrong, and therefore is right. Is it necassary, who knows, but at least the ventilating capability is there should the engine need it.
Really? And without a means to vent, where does said pressure go ? Out the oil seals? Perhaps you are too young to remember GM engines with vented oil caps on the valve covers....."decades ago"....
My statement is true. Initially engines did not have crankcase ventilation systems of any sort. Pressure was relieved through the seals, etc. The engines then, just as they would now, will run without a ventilation system. They are not needed. Pistons are needed, valves are needed, but ventilation systems are not.
So far, you have failed to put me in my place and only appear to be taking these comments too personally. Also, please try to understand the context in which statements are made. Never did I suggest that having no ventilation for crankcase pressure was ideal or beneficial. You failed to comprehend what was written.
Old Dec 16, 2010 | 03:16 PM
manley845's Avatar
manley845
For those interested.
With the stock PCV system and stock motor set-up the dipstick would pop up out of the tube due to pressure in the crankcase. This would only happen after high rpm runs.
After installing the breather I have not had this issue.
Additionally, oil consumption between oil changes has reduced by a small, but noticable amount.
disclaimer: your results may vary, based on your own engine set-up and driving habits
Old Dec 16, 2010 | 03:23 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
If i understand correctly, I have 2 options:
a) breather setup will vent crankcase pressure during boost that would otherwise be too much for the PCV valve
b) Oil catch can setup w/ breather to catch the extra oil instead of letting it vent into the air.
c) Vaccum pump: not sure what kind or where this goes, but i think it aides the PCV system.
Old Dec 16, 2010 | 03:50 PM
lucky131969's Avatar
lucky131969
You pegged me. I am indeed a follower. I just do to my car, what everyone else is doing. I solicit the forum any time I have to make a decision on a new mod. All I know, is that shiny thing under my hood made the car faster....but to articulate the impact on the engine, or crankcase pressure.....forget about it.....way over my head.
You might have something there. Some of these topics are just too advanced for someone of my meager intellect. I fail to fully comprehend the complexities of mechanical assemblies, like internal combustion engines.......and when it comes to that electrical stuff....hell......I'm just lost. I'm glad there are forum members like you, to make sense of it all......for the rest of us.
Old Dec 16, 2010 | 04:00 PM
manley845's Avatar
manley845
a) breather setup will vent crankcase pressure during boost that would otherwise be too much for the PCV valve Yes
b) Oil catch can setup w/ breather to catch the extra oil instead of letting it vent into the air. Not exactly. The breather means that it will vent to the atmosphere. The catch can simply means that the oil vapor that normally goes into the intake manifold will instead be trapped in the catch can. This set-up will give vacuum to draw out crankcase pressure, will allow excess to vent through breather, and allow the intake to remain cleaner. This is what many people have set-up
c) Vaccum pump: not sure what kind or where this goes, but i think it aides the PCV system. it replaces the traditional PCV system. some people use the A.I.R. pump as a vacuum pump. It applies vacuum to the crankcase much like the intake manifold vacuum does with the stock PCV system, but it can handle more vacuum and volume. Great for boosted and high rpm applications
There is also a set-up called a crankcase evac system that can be installed. It uses breathers that have a hose which runs down to a check valve on the exhaust. The vacuum of the exhaust passing over the valve draws air pressure out of the engine. The LS1 in the Vette is not ideal to use this method because of space limitations, but it can be done.
Old Dec 16, 2010 | 04:06 PM
manley845's Avatar
manley845
Now you're getting it
Hey man, I'm just playing with ya.
I can tell by your tone that you're not a douche', which is why I was enjoying being a butthead. :o
I know what you are getting at with your initial comments. And I knew I'd get feedback from the 'ghetto looking' comment, but it's just my opinion, no big deal.
Have a great day and a Merry Christmas!!!
Old Dec 16, 2010 | 04:20 PM
TheRadioFlyer
Supporting Vendor
I'm thinking the catch can setup would work best for me.....but my EE setup won't fit in the original location in front of the passenger cylinder head. Anyone know of a catch can that can be mounted elsewhere?
Old Dec 16, 2010 | 04:29 PM
manley845's Avatar
manley845
You can mount it anywhere you want. Just need longer hose. I've seen some mounted to the firewall area near the battery.
If you install one, post some pics for us
Old Dec 16, 2010 | 07:14 PM
TheRadioFlyer
Supporting Vendor
Good news, I found my EE catch can.
I'm thinking about mounting it just outside the battery area. I'm thinking about using the AIR block off bolts on the headers as a anchor point for the catch can bracket. This would mount the can at about 45 degrees to vertical and still allow easy access to the can bottom for maintence.
Thoughts?
Old Dec 16, 2010 | 08:01 PM
lucky131969
Thoughts?
I think that location is a poor choice. First, because you don't want anything hanging from that flange, as they do break without notice. Second, tilting the catch can at a 45 degree angle reduces the capacity to about 1/2. Just my uneducated opinion.
Old Dec 16, 2010 | 08:27 PM
Bill Dearborn's Avatar
Bill Dearborn
He may be to young but I remember that the 265 and 283 mouse motors that I had in my 55 Chevy had a large vent tube that went down the back side of the block and vented the crankcase under the car.
Bill
Old Dec 16, 2010 | 08:52 PM
  #33
LoneStarFRC's Avatar
LoneStarFRC
Bill
Called a "road draft" tube. It had a "bologna slice" (45* angle) tip and relied on forward motion of the car to create a slight vacuum over the tip as air passed over the tip. When sitting at a traffic light, you could tell who it was that had ring seal problems with their cars because there would be puffs of oil vapor coming from under the car.
Inside the engine, at the rear of the lifter valley, was a sheet metal cylinder (canister) installed, designed to be a "baffle" to prevent too much liquid oil from being sucked into the road draft tube. We used to call it "the beer can".
Old Dec 16, 2010 | 09:07 PM
  #34
lucky131969
Old Dec 16, 2010 | 10:41 PM
  #35
LoneStarFRC
The beer can!! Dayum Mike. That there's a museum piece.
Old Dec 16, 2010 | 11:47 PM
  #36
bucketlist1957's Avatar
bucketlist1957
Default Breather
I added one because I didn't like the amount of oil getting into the catch can. I am leaving it on for a couple thousand miles to see if it makes a difference.
[IMG][/IMG]
Old Dec 17, 2010 | 12:35 AM
  #37
TheRadioFlyer
Supporting Vendor
Well based on early measurements, it won't be hanging, from this, more sitting on it so there's not much stress on it. I also plan to secure a support piece somewhere on the valve cover. Also the can will be in the upright position.
To Small filter on oil cap?
Old Dec 17, 2010 | 06:41 AM
  #38
lucky131969
Sounds like you have it all figured out
Old Jan 13, 2011 | 09:41 PM
  #39
TheRadioFlyer
Supporting Vendor
Mechanically speaking, all pros. (depending on the type, and frequency of cleaning, and oil film or drip may be noticed on the engine though. Keep it clean is all)
Personally, I do not trust the effectiveness of the PCV system to properly vent the crankcase so I installed a $10 Mr.Gasket one from Autozone. I clean it every so often and all is well. No more dipstick popping up, and I've noticed less oil consumption between oil changes.
Ended up getting my catch can installed and a breather cap from ECS
During the last dyno tune, I noticed oil starting to leak a little from the breather filter. I wiped up as much as I could but some started dripping on hot stuff making a rather nasty smell.
I saw somewhere a few setups that had a hose that came out of the oil cap and went somewhere (probably a catch can) I'd like to replicate this running both the PCV line and the oil cap line to the catch can input with a T fitting to keep oil from leaking in the future.
Question: could I run the vac line from the catch can upstream of the blower on the intake to provide suction at all engine speeds? (I assume the catch can would keep any oil from getting into the head unit intake)
Old Jan 15, 2011 | 07:54 PM
  #40
Z0600's Avatar
Z0600
fwiw my engine builder(schwanke short blocks) told me that the ls engines are designed to be vented on the driver side valve cover. so by venting the passenger side cover like i see so many people do (due to the ease of replacing the oil filler cap with a breather) i would have to say that this is not proper for functionality purposes especially if you are still using a pcv system as it allows unmetered air into the manifold.
just an observation so please dont "jump" me if this is not correct, but inform me in a civilized way
