Code C1243HC BPMV
Old Dec 17, 2010 | 01:23 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Default Code C1243HC BPMV
Ok Gents and Ladies, This is the current code for my '99 Coupe with Active Handling. Ground test shows good and the book states its motor is turning slow. Only happens on startup and if I clear the code, it stays gone till the next morning at cold startup at which time it comes back. Has anyone repaired the BPMV before or know of someone who can? Other options or thoughts?
Old Dec 17, 2010 | 04:11 PM
seoulbrooks's Avatar
seoulbrooks
There is a thread on energizing the motor untill you clear this fault. I'l look around for it....
Old Dec 17, 2010 | 04:17 PM
87SAM's Avatar
87SAM
I have not heard of anyone repairing them. I replaced the BPMV on my 2000 last year. Some people have had success by stomping on the breaks repeatedly on wet roads to exercise the pump. This did not help mine. There is also a thread out there which describes how to take the EBCM off and hooking up 12V to pin 8 of the motor and exercise it that way. This also did not work or me as motor was shot and was pulling over 20amps.
Here is a decent link:
http://forums.corvetteforum.com/c5-t...c-c1243-h.html
Old Dec 17, 2010 | 05:14 PM
dgrant3830's Avatar
dgrant3830
Very interesting read and Thank You. Hopefully we'll get a little rain shortly and I'll force that pump to run otherwise will have to manually run it with a wire to pin 8
Old Dec 17, 2010 | 07:57 PM
dgrant3830's Avatar
dgrant3830
I decided to gain access to it to test, so removed the radiator and behold, I discover the radiator had a hairline crack in it. The BPMV had dried coolant all over it as well from the leak but the connector to the EBTCM was clean and dry. Anyway, ordered a radiator. Hoping to avoid spending for a new BPMV.
Old Dec 18, 2010 | 01:55 PM
dgrant3830's Avatar
dgrant3830
This morning, I took the EBTCM off the BPMV and manually applied power to pin 8 as described in the thread from earlier in the year that was referenced to me by "87SAM". The BPMV motor did in fact run although it was a bit sluggish. I ran it several more times and up to as much as 30 seconds. It smoothed out real nice. I'm therefore assuming the brake fluid is needing to be flushed all the way through and I do have a brake pressure bleeder, so I'll be getting to that after the new radiator gets here and installed.
Old Dec 18, 2010 | 05:10 PM
87SAM's Avatar
87SAM
That's good news! You wasted no time jumping all over that one!
Old Dec 18, 2010 | 06:26 PM
dgrant3830's Avatar
dgrant3830
Well, when I discovered the radiator crack and got it pulled out, the EBTCM/BPMV is right there and easily accessible. No sense in waiting around. It would have been a lot harder when everything else was back in. So for now, I'll have to wait for the new radiator.
Old Dec 18, 2010 | 06:45 PM
sjbrothers's Avatar
sjbrothers
Default Been There Done That
If you really want to exercise the BPMV then here are a couple of posts that I made on building an exerciser. I changed the brake fluid using the BPMV motor to pump the fluid through the system. I have not had a fault since I changed the fluid.
http://forums.corvetteforum.com/c5-t...xed-again.html
Here is a diagram of my BPMV
http://forums.corvetteforum.com/c5-t...-handling.html
Old Dec 18, 2010 | 07:25 PM
dgrant3830's Avatar
dgrant3830
I was going to use a pressure bleeder that I have already but having a way to actuate the pump without removal would be great. I see your pictures but where are you connecting this? Did you come up with a connector for it since it doesn't look like wiring for the serial data buss?
Old Dec 19, 2010 | 01:50 PM
sjbrothers's Avatar
sjbrothers
PM sent
Old Dec 19, 2010 | 03:21 PM
DeeGee's Avatar
DeeGee
Interesting thread Dave. Glad youre making progress.
Old Dec 19, 2010 | 04:25 PM
dgrant3830's Avatar
dgrant3830
Yeah, I'm trying. Since I got the car back from my son a couple of months ago now, I've been fixing this and that on it. First was the driver's window regulator wore out. The clutch was already toast when I got it back so its now got a new LS7 clutch in it. Just replaced a weatherstrip and the driver's side havc actuator and now discovered this leaking radiator at the same time I was looking at this code showing up for the BPMV. Also have a TPS transmitter on order right now as well. Oh well, little by little its coming together. As I've said to many people in here, nothing lasts forever and that includes my own cars.
Old Dec 20, 2010 | 03:39 AM
DeeGee's Avatar
DeeGee
But with its mileage I think your car is unique
Old Dec 20, 2010 | 04:35 AM
seoulbrooks
dgrant....glad you got it going again..... Merry Christmas from lovely downtown Seoul Korea to all you Vet lovers!
Old Dec 20, 2010 | 09:24 AM
dgrant3830's Avatar
dgrant3830
And a very Merry Christmas to you all as well! Yeah, my car has a ton of miles on it so the interesting part is that I'm experiencing things now or earlier that others will have happen to them later on. Hopefully I'll have the new radiator sometime this week so I can put her together again.
Old Dec 23, 2010 | 06:20 PM
dgrant3830's Avatar
dgrant3830
I got the new radiator installed today and fired it up. No more codes from the BPMV so the next on the list will be flushing all the brake fluid from the master cylinder, through the BPMV to each wheel.
To Code C1243HC BPMV
